defrost system not working correctly. tested sensor with meter there is continuity. replaced defrost timer. when putting timer in defrost mode only a low voltage reading at heater terminal. if I run 120 volt cord to heater it melts the ice formed on coils . The defrost timer was a used one and not sure it works correctly :confused:
