The touch pad responds to command but the igniter on the oven won't heat. The broiler igniter will get red but the gas doesn't come on (I assume that is a safety thing?) The oven igniter was replaced in 2008. Presently the igniter looks intact and I can't see any debris on it -it remains "sparkly". Should I assume it's an igniter prob and replace it or should I worry about something else?
