Tania Corkery
#1 Posted : Thursday, December 31, 2009 3:41:45 PM(UTC)
Tania Corkery
We have a Maytag Top loading washer purchased November 4, 2006 that will not agitage through any cycle (wash or rinse). Washer will fill with water ...but will not wash. I can spin the water out.
Do you have any suggestions on how my husband could fix the washer? :confused:
sidfink43
#2 Posted : Saturday, January 2, 2010 5:17:07 PM(UTC)
sidfink43
It is not clear from your post but it souns like it will spin ok, just not agitate. If it won't spin or agitate check the lid switch. If it is ok, take off the front and see if
1.The transmission pulley will turn clockwise, if not the transmission is faulty.
2. See if the motor pivot spring and glides are ok. The motor is designed to move to act as a clutch. It probably does since your machine will spin.
3. Take off the belt and see if the motor turns in agitation mode. If not, check the wiring to the motor and the connection to the motor. Clean the connection with contact cleaner and reseat.
4. If everything checks out then the problem may be in the timer not sending the motor power to agitate.
See the service manual for how to do this.
http://repair2000.com/Li...maytagatlantiswasher.pdf
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
