Guest
#1 Posted : Saturday, July 29, 2023 5:24:40 AM(UTC)
Guest
Rank: Guest
United States
I was given the above model Maytag washer with s/n 11361046UD with a few problems. One of the problems was the belt was damaged and needed to be replaced. I bought a new belt from my local dealer under the p/n WP21352320 which matches the old belt properly. Installing the belt is easy as it is wrapped around the 3 pulleys and seems to be OK but on a parts page it shows a slipper foot on the back side of the motor mount. This part is no longer available and I dont understand how the motor stays in position without it. The front of motor has 2 sliders/plastic biscuits but the back is free to move without restraint ? Can anyone help to point me in the right direction to make this fit/work as it was originally built. ? HELP !!!
Guest
#2 Posted : Saturday, July 29, 2023 7:28:03 AM(UTC)
Guest
Rank: Guest
United States
After much checking on Maytag sites for the source and p/n of the small guide for the motor support plate which is no longer available. I found a piece of a plastic drum guide from a dryer. It was about the size and configuration of what I think was used when this washer was built by Maytag about 25 years ago. I drilled a hole thru it and used a piece of all-thread and put it into a newly drilled hole in the base of the washer and hopefully it will work . If anyone needs pictures of the item contact me at my e-mail address jaybird@mtco.com
