moodster
#1 Posted : Thursday, December 17, 2009 1:40:26 PM(UTC)
moodster
I have a kitchen aid that quit running and gave the 7 blinks on the the clean led. i replaced the elect. control panel and heater coil. it lasted 2 weeks and failed again with the same fault. i repalced the control panel and coil again and it didn't get thru a cycle. i ohmed out all the heater cucuit and everything seems ok. the K2 relay is normally open. . I bypassed the door switch to see what was going on and found the water filled but barely came out of the lower spray arm. Could the pump be blocked/bad or something else?
moodster
#2 Posted : Saturday, December 19, 2009 2:07:58 AM(UTC)
I cannot find any info on the given model. Please check it.
Can find DLB but then it jumps to DLW (no DLS's listed).
Here is an example of a model number KUDP01DLBS1.
When you checked the heater did you also check the hi-limit thermostat.
Many units have one of these.
Also if it has a thermistor for reading the temperature, check it should be around 50,000 ohms.
I am assuming that when you checked the devices you had disconnected one side of it (if possible) to ensure that you did not read an alternate/parallel circuit path.
Kitchenaid Oven range Superba kgsc308lss0 not heating up (Oven Repair (including Ranges and Cooktops))
by rattty Yesterday at 6:51:16 PM(UTC)
Kitchenaid KDTM604KPS0 (Dishwasher Repair)
by Guest 5/12/2024 5:24:44 AM(UTC)
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 4/30/2024 6:27:57 PM(UTC)
KitchenAid freezer door stuck (Refrigerator & Freezer Repair)
by willeaton 4/18/2024 7:31:34 AM(UTC)
KitchenAid KSC25INSS01 issues (Refrigerator & Freezer Repair)
by KKellyNC 4/16/2024 7:28:06 PM(UTC)
Kitchenaid KSSC48QMS02 (Refrigerator & Freezer Repair)
by VinRenzi 4/2/2024 6:26:11 AM(UTC)
Kitchenaid Refrigerator Ice chute frosting up and clogging (Refrigerator & Freezer Repair)
by Guest 3/26/2024 9:05:12 AM(UTC)
Built-In Kitchenaid Mdel KSSC42QMS00 Refrigerator (Refrigerator & Freezer Repair)
by Guest 3/25/2024 6:29:18 AM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Kitchenaid ktdm354dss3 doesn’t close completely at the top (Dishwasher Repair)
by Guest 2/29/2024 12:36:40 PM(UTC)
KitchenAid Gar Range - Oven Intermittent Lighting (Oven Repair (including Ranges and Cooktops))
by JDinKTX 2/25/2024 5:05:21 AM(UTC)
Kitchenaid Gas Range KGRA806PSS00 (Oven Repair (including Ranges and Cooktops))
by bobr55 2/16/2024 1:31:09 PM(UTC)
Kitchenaid Stand Mixer K5SS - bowl wants to pop out (General Talk)
by mikehd 2/5/2024 2:24:56 PM(UTC)
Kitchenaid quits mid cycle, goes to cancel/drain (Dishwasher Repair)
by T_mich 2/4/2024 11:11:49 AM(UTC)
Kitchenaid side-by-side KSRK25FVMK00 - which starter relay? (Refrigerator & Freezer Repair)
by scopus1972 1/19/2024 8:04:22 PM(UTC)
