MByram
#1 Posted : Sunday, April 22, 2018 11:36:12 PM(UTC)
MByram
I have replaced virtually all thermostats and thermal couplings and cut offs - and have checked continuity on the heating element - it is good. The heat was working until yesterday but we had suspected for the last couple months that it was not working all the time. yesterday it stopped working for about two hours of running then came on for about 1 hour - now it has not come back on in a few hours running. The vent tube appears clear - I feel strong airflow when running the dryer without heat. I have shut the circuit breakers on and off - they did not seem tripped. Any ideas out there why it is not heating?
dufuss
#2 Posted : Monday, April 23, 2018 1:23:19 PM(UTC)
dufuss
Probably timer. Use schematic to verify contacts closing at proper time for each cycle. Wiggle and / or slightly turn knob while checking continuity. ( of course disconnected from power source)
Dryer Will Not Heat (Dryer Repair)
by coreyhall 3/6/2017 1:18:48 PM(UTC)
Dryer will not heat or turn off (Dryer Repair)
by jesus freak 1/17/2016 5:25:22 PM(UTC)
Dryer will not heat (Dryer Repair)
by rwebb 12/4/2015 12:44:48 PM(UTC)
Dryer will not heat and will not shut off (Dryer Repair)
by HMH1983 9/23/2015 9:44:16 PM(UTC)
Default Dryer will not heat, timer does not work (Dryer Repair)
by gotcoffee82 3/1/2015 10:37:21 PM(UTC)
Dryer will not heat up (Dryer Repair)
by kpholler 12/2/2014 6:42:57 PM(UTC)
Gas dryer will not heat up (Dryer Repair)
by Ahhnother8 10/9/2014 11:16:39 PM(UTC)
Kenmore Dryer Will Not Heat After Replacing Everything (Dryer Repair)
by jlewis57 10/1/2014 3:28:50 PM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 5:46:05 PM(UTC)
Dryer Will Not Heat, But All Parts Test OK (Dryer Repair)
by kamera 9/6/2014 12:33:05 PM(UTC)
Roper dryer will not heat (new parts installed too) (Dryer Repair)
by xenomorphlv426 2/1/2014 11:49:03 AM(UTC)
GE harmony profile gas dryer will not heat (Dryer Repair)
by Thespiderman20 9/10/2013 8:44:45 PM(UTC)
Dryer will not heat. (Dryer Repair)
by modelshop8624 7/4/2013 4:24:12 PM(UTC)
Kenmore Dryer will not heat but the drum runs (Dryer Repair)
by asirota1 3/25/2013 11:33:52 AM(UTC)
by creative582 1/6/2013 5:52:04 PM(UTC)
