ussharryae21
#1 Posted : Tuesday, November 3, 2009 5:58:59 AM(UTC)
ussharryae21
the water will not drain after washing, replaced pump, and still will not drain. is the problem in the timer switch?, or what else could it be? Thank you for all of your help!!!!!!!!!
sidfink43
#2 Posted : Wednesday, November 4, 2009 3:39:12 PM(UTC)
sidfink43
It is possibly in your timer, but you need to check out some things first.
1. Make sure there is nothing obstructing the flow of water from draining out of the washer.
2. Determine if the pump is getting 120v when it is supposed to be operating. If not, and the drains are clear then the timer may be the problem. If it is getting current then you still have a defective pump.
Frigidaire Dishwasher / Water won't drain (Dishwasher Repair)
by ruzquiano 8/27/2014 11:29:59 AM(UTC)
Spin cycle does not start and water won't drain. (Washer Repair)
by civictuner95 7/10/2013 4:16:20 AM(UTC)
by gdicio 11/9/2012 11:06:10 AM(UTC)
Kenmore dishwasher water won't drain (Dishwasher Repair)
by Cujimmy 9/6/2012 8:04:30 PM(UTC)
No final cycle water won't drain (Washer Repair)
by ajones6831 5/17/2011 10:32:21 AM(UTC)
by ajones6831 5/17/2011 10:18:52 AM(UTC)
Water Won't Drain (Washer Repair)
by Lester3 12/16/2010 1:44:38 PM(UTC)
Water won't drain in dishwasher (Dishwasher Repair)
by elkstu 7/30/2010 10:12:32 AM(UTC)
GE Washer water won't drain (Washer Repair)
by nzbarzh 6/30/2010 3:07:02 PM(UTC)
Water won't drain from Rinse cycle (Dishwasher Repair)
by willowj47 6/16/2010 8:07:56 AM(UTC)
Water won't drain completely resulting in rancid smell (Dishwasher Repair)
by cmccloskey79 11/30/2009 12:40:01 PM(UTC)
Water won't drain, no power! (Washer Repair)
by longleggedfirecracker 9/12/2009 2:00:03 PM(UTC)
All Water won't Drain (Dishwasher Repair)
by CanuckDuck 8/11/2009 6:17:09 AM(UTC)
no spin, washer water won't drain (Washer Repair)
by kabi54 7/17/2009 10:32:12 AM(UTC)
Kemore 90 series Water won't drain! (Washer Repair)
by eshn7 6/14/2009 6:45:49 PM(UTC)
