Mechris
#1 Posted : Tuesday, October 25, 2016 6:30:42 AM(UTC)
Mechris
I had an issue with my dryer not heating and timer not advancing. I checked the continuity on all of the switches and thermostats and found the thermo reset bad. Reset it and got it heating up again but timer not advancing. Disassembled the timer and couldn't find and issue but motor would not run. Went ahead and replaced it thinking the motor was bad. Put it back in service but it is still not advancing. I can manually advance it and it shuts down at cycle end but not automatically. Is there something else that may be the problem? There is what appears to be a relay next to the timer and connected to it. Could this be the problem? How do I test it?
ThatGuy
#2 Posted : Tuesday, October 25, 2016 11:28:52 AM(UTC)
ThatGuy
Groups: Expert
United States
Check the resistor inline to the timer motor. I've seen them fail before. Yours may look different than the picture, but it still does the same job.
Whirlpool 279872 Resistor - AppliancePartsPros.com
Part 6
UserPostedImage
Mechris
#3 Posted : Wednesday, October 26, 2016 9:05:54 AM(UTC)
Mechris
Thanks. On my timer there is a little square black relay looking item with two wires connected from it to the timer. I assume this is the resistor you speak about. How can I test it?
ThatGuy
#4 Posted : Wednesday, October 26, 2016 9:57:43 AM(UTC)
ThatGuy
Groups: Expert
United States
Are you talking about this part?
UserPostedImage
That's a end of cycle buzzer.
ThatGuy
#5 Posted : Wednesday, October 26, 2016 10:28:28 AM(UTC)
ThatGuy
Groups: Expert
United States
Resistor can take many forms.
UserPostedImage
UserPostedImage
or this
UserPostedImage
Big or small, resistors test the same way.
https://www.youtube.com/watch?v=cZFZc2r7aCM
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
GE gas dryer timer will not advance on Easy Care feature (Dryer Repair)
by MrsG 1/23/2015 5:38:59 PM(UTC)
by stevechar 9/21/2014 8:33:08 AM(UTC)
Dryer will not heat and timer will not advance (Dryer Repair)
by MNJames 9/15/2014 2:46:05 PM(UTC)
Timer will not advance after lightning strike (Dryer Repair)
by jwahl16 9/3/2014 2:23:07 PM(UTC)
New timer will not advance (Washer Repair)
by meganbella 4/5/2013 7:02:18 AM(UTC)
GE washer timer will not advance. (Washer Repair)
by Chumlord 6/29/2010 2:52:09 PM(UTC)
Dryer timer will not advance (Dryer Repair)
by Brian7780 6/19/2010 7:23:44 AM(UTC)
Timer will not advance in cool down part of cycle (Dryer Repair)
by Blake1111 3/30/2010 2:00:14 PM(UTC)
Kenmore washer timer will not advance past the wash cycle, will not spin or drain H20 (Washer Repair)
by ambsdr4god 11/8/2009 4:12:08 PM(UTC)
Timer will not advance in Auto Dry (Dryer Repair)
by KSherer 6/2/2009 6:17:52 PM(UTC)
Maytag timer will not advance (Washer Repair)
by Robinscs 2/18/2009 2:40:20 PM(UTC)
Dryer Timer Will Not Advance (Dryer Repair)
by cyclone 1/15/2009 9:42:24 AM(UTC)
Timer will not advance (Dishwasher Repair)
by geraki 12/11/2008 10:08:47 AM(UTC)
