gbrogan
#1 Posted : Friday, October 30, 2009 9:15:55 AM(UTC)
gbrogan
The drum turns but I am not getting any heat. I have it partially torn apart but don't know how to tell if it is a switch (thermostat) or element.
chito macario
#2 Posted : Friday, October 30, 2009 5:30:42 PM(UTC)
chito macario
my dryer turns but no heat (whirlpool) so what is the problem
#3 Posted : Sunday, November 1, 2009 4:16:13 AM(UTC)
chito macario
Please start you own thread using POST NEW TOPIC hijacking/ piggy backing on a thread when your model is different will just confuse things. Also include your model number.
Thanks in advance
gbrogan
Replacement parts for AMANA LE4407W | AppliancePartsPros.com
First try flipping your breaker off/on a couple times slowly. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure it with a meter L1 to L2 should be 240 volts which is required by the heater.
Next check the heater itself, should be around 10 ohms. Sometimes you can see the break.
Next would be:
Thermal fuse Item 4 Section 6
Operating Thermostat Item 24 Section 10
Hi-limit thermostat Item 6 Section 6
All should be 0 ohms at room temperature.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
