billpulsipher@gmail.com
#1 Posted : Friday, August 28, 2015 11:25:19 AM(UTC)
My refrigerator had been in storage and I plugged it in on Tuesday. It took over 24 hours for refrigerator to cool to 38 degrees and the freezer still has not dropped below 16 degrees. Before storing all worked and it had recently received a new compressor. Thanks in advance
#2 Posted : Wednesday, September 9, 2015 8:27:25 AM(UTC)
Freezer will get to around 12 degrees, but no cooler. Should be zero degrees. Any ideas?
#3 Posted : Thursday, September 10, 2015 2:40:31 AM(UTC)
I cannot find any info on the given model number.
Please check it.
Is the compressor running all the time except when the unit goes through a defrost cycle?
If the unit has two fans (condenser/compressor and evaporator/freezer) are they both on when the compressor is on?
If yes to both the above, remove the cover in the freezer so you can inspect the evaporator coils.
They should have a fairly even coating of frost on them and not be frosted/iced over to the point that the fan cannot pull air through them.
If there is frost in one area usually where the freon enters the coils then you probably have a sealed system problem.
This will be an expensive repair and often it makes more sense to put the dollars towards a new unit.
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 9/24/2015 9:57:47 AM(UTC)
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
Belarus Jasonywu 8/6/2015 2:05:17 PM(UTC)
by Suzalasue 5/28/2015 6:08:45 AM(UTC)
by wnorton 1/27/2015 3:21:20 PM(UTC)
Freezer not cold enough, fridge working (Refrigerator & Freezer Repair)
by JDM1oc 12/4/2014 8:36:25 PM(UTC)
