chazhars
#1 Posted : Monday, December 29, 2014 4:15:19 PM(UTC)
chazhars
Washer fills then stops running. I had the drain pump off twice. The first time it had a quarter in it, I don't know if it damaged it. It then filled and stopped again. I took the pump out again. It filled and stopped. I then drained the pump to get the door opened. I have removed the door switch and it checks that the door button switch is working. Does this sound more like the pump or the door switch is bad. Or is there something else I should check?
sidfink43
#2 Posted : Tuesday, December 30, 2014 5:31:52 PM(UTC)
sidfink43
This sounds like an electronics problem. Under the top or inside the lower service panel you should find the tech notes that will tell you how to put it into diagnostic mode and generate some error codes. Focus on the main control unit.
front load amana door misalign (Washer Repair)
by wilsonjiaho 5/17/2024 1:02:16 PM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Amana compressor issues (Refrigerator & Freezer Repair)
by Guest 1/1/2024 12:42:43 PM(UTC)
Amana fridge warm, freezer cold (Refrigerator & Freezer Repair)
by agdodge4x4 12/25/2023 6:22:47 PM(UTC)
NTW4516FW3 Amana Top Loader Washer (Washer Repair)
by KMags 11/28/2023 4:52:44 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Amana dryer motor growl at startup (Dryer Repair)
by Guest 9/21/2023 3:35:28 AM(UTC)
Amana fridge SX26VE door seals, hens teeth? (Refrigerator & Freezer Repair)
by Guest 8/31/2023 10:58:17 AM(UTC)
Amana washer not filling properly (Washer Repair)
by carcajou 5/12/2023 10:53:05 AM(UTC)
Warm Amana (Refrigerator & Freezer Repair)
by csmdew 4/6/2023 6:29:02 AM(UTC)
Amana electric dryer model NED4800VQ1 (Dryer Repair)
by thorning 9/22/2022 8:05:59 AM(UTC)
Amana glass part #31688701B (Oven Repair (including Ranges and Cooktops))
by Guest 9/1/2022 1:02:28 PM(UTC)
