owentop
#1 Posted : Tuesday, September 11, 2012 6:19:17 PM(UTC)
owentop
washer will not fill with water. spin cycle only cycle that work.
Jagsmaned
#2 Posted : Tuesday, September 11, 2012 8:30:47 PM(UTC)
Jagsmaned
Hello,
Does it sound like the water valve is humming. If it does then you would want to check to make sure your water supply valves were not shut off. If they are on you could pull the hoses off unit and check to see if the screens inside the water valve are clogged. If they are clogged you would want to clean them and then check to see if water coming into unit. The unit will not run through cycles without water in the unit.
Speed Queen washer problem (Washer Repair)
by Guest 7/21/2023 1:04:45 PM(UTC)
Kenmore Series 80 washer problem (Washer Repair)
by sarahs 3/13/2023 5:55:33 PM(UTC)
Kenmore Elite Dishwasher Problem (Dishwasher Repair)
by AndyH01 3/31/2022 3:33:31 AM(UTC)
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
Kitchenaid dishwasher problem - water path question (Dishwasher Repair)
by bmsamson 2/6/2020 9:03:09 AM(UTC)
Kenmore VMW 22352 Washer Problems (Washer Repair)
by Papa_omero 3/11/2019 5:25:53 PM(UTC)
Whirlpool Duet Sport Washer problems (Washer Repair)
by bdmbluegrass 1/11/2017 11:54:22 AM(UTC)
Washer problem (Washer Repair)
by Roseazbell@gmail.com 10/22/2016 1:18:49 PM(UTC)
Whirlpool gold washer problem on spin cycle (Washer Repair)
by Bblazek 9/21/2015 7:31:09 AM(UTC)
by 7Bucks 7/23/2015 11:29:42 AM(UTC)
Dishwasher problem (Dishwasher Repair)
by malinz 7/10/2015 5:38:35 AM(UTC)
dishwasher problem (Dishwasher Repair)
by pstreet40 5/23/2015 9:15:33 AM(UTC)
Kenmore 80 Series Washer problem (Washer Repair)
by castora5 4/15/2015 7:30:44 PM(UTC)
washer problems (Washer Repair)
by porterbridges 1/18/2015 10:53:23 AM(UTC)
by dennis h etzler 1/4/2015 6:37:41 AM(UTC)
