2 Pages<12
1TechDad
#11 Posted : Friday, May 18, 2012 7:36:35 PM(UTC)
1TechDad
Originally Posted by: richappy Go to Quoted Post
Just to clarify things. If you have a rather large start device and not a ptc device, measure across the output (compressor side) side by side pins, should be 5 - 10 ohms. If way off value, like 27 ohms, it's bad.
What's a ptc device?? Socket to socket = 27 ohms. The run cap., I can't measure, as my meter keeps "ranging" on me.
#12 Posted : Friday, May 18, 2012 11:45:11 PM(UTC)
Looks like you have a bad start device. A ptc start device is a rather small, black plastic device.
1TechDad
#13 Posted : Saturday, May 19, 2012 8:36:16 AM(UTC)
1TechDad
Copy that, will order a new one A.S.A.P...
#14 Posted : Saturday, May 19, 2012 10:32:34 AM(UTC)
Measure across the two,round, side by side output female pins on the start device, should be like 5- 10 ohms.
1TechDad
#15 Posted : Tuesday, May 22, 2012 5:19:35 PM(UTC)
1TechDad
I ordered and received the new part using the part number you provided. The new part looks different than the existing one, the new part shows "OL" across the sockets that are side/side. The new start device shows "OL" across the same two pins. The existing run cap. shows "OL" across the blades when I ohm it out. What next??
#16 Posted : Tuesday, May 22, 2012 11:51:04 PM(UTC)
Just install the new start device and plug into it the run capacitor and fridg connector.
1TechDad
#17 Posted : Wednesday, May 23, 2012 6:23:06 AM(UTC)
1TechDad
I did that, and it sounded the same. Should I let it run for awhile?? Do the measurements I provided for both devices sound OK??
#18 Posted : Wednesday, May 23, 2012 7:31:28 AM(UTC)
Let it run for a period.
1TechDad
#19 Posted : Wednesday, May 23, 2012 10:39:23 AM(UTC)
1TechDad
It's run for about 3 hrs. now, and it doesn't appear to be cooling. It sounds alittle quieter, as I found two copper lines vibrating against each other and spread them apart. There doesn't appear to be much air flow inside the freezer either. Is there a fan behind the rear inside panel??
#20 Posted : Wednesday, May 23, 2012 2:11:55 PM(UTC)
Pull off the freezer back panel and check the frost pattern, if total, heavy frost, you have a defrost problem, if little frost, that confirms a bad compressor/refrigerant leak.
LG Refrigerator not cooling; compressor clicking. (Refrigerator & Freezer Repair)
by pmrowley 11/8/2023 7:07:53 AM(UTC)
Jenn-air refrigerator not cooling (Refrigerator & Freezer Repair)
by pke 9/20/2023 4:18:40 PM(UTC)
New GE refrigerator not cooling to set temp of 35 (Refrigerator & Freezer Repair)
by VarMan 6/16/2023 5:05:53 PM(UTC)
Freezerless Refrigerator not cooling (Refrigerator & Freezer Repair)
by rehawtho 7/19/2022 9:11:09 AM(UTC)
Whirlpool Refrigerator Not Cooling - Intermittently (Refrigerator & Freezer Repair)
by ljsmith9999 2/3/2022 6:53:41 AM(UTC)
Please help me diagnos refrigerator not cooling (Refrigerator & Freezer Repair)
by beaverislander 1/1/2022 6:18:12 AM(UTC)
Refrigerator not cooling, beeping (Refrigerator & Freezer Repair)
by Rtff 12/22/2021 6:55:11 AM(UTC)
Whirpool Refigerator WRS342FIAB00 Refrigerator Not Cooling Consistently/ Freezer Cold (Refrigerator & Freezer Repair)
by edge10 7/10/2021 8:07:34 AM(UTC)
GE Refrigerator not cooling properly/ water not dispensing (Refrigerator & Freezer Repair)
by tatkins85 3/18/2021 6:48:15 AM(UTC)
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Refrigerator not cooling - only bottom portion of coils covered in frost (Refrigerator & Freezer Repair)
by redr8er 12/26/2018 10:38:33 AM(UTC)
Samsung Refrigerator Not Cooling (Refrigerator & Freezer Repair)
by viper1522 11/8/2018 4:50:22 AM(UTC)
Refrigerator not cooling, bottom freezer over freezing and frosty (Refrigerator & Freezer Repair)
by Libboo 10/13/2017 2:51:02 AM(UTC)
Refrigerator not cooling enough (Refrigerator & Freezer Repair)
by skibumynn 4/8/2017 1:48:40 PM(UTC)
Whirlpool Refrigerator not cooling (Refrigerator & Freezer Repair)
by MCW750 10/12/2016 7:25:49 AM(UTC)
2 Pages<12
