My machine was in outside storage and the pump froze and cracked. I replaced the pump and belt and after getting the belt on right it worked fine for a few days. Now the washer basket does not drain in the spin cycle. I took the pump off and looked for obstuctions, none found. I reassembled and it still does not pump out. The port for the washer drain hose is at the basement ceiling. If I lower the drain hose it does drain (into a 5 gallon bucket level with the top of the washer)
Joined: 3/29/2009(UTC) Views messages in topic : 11,699
Well since it will drain there is no obstruction. This pump is directly driven by the motor, so if the motor is turning there is something wrong with the pump.
