dmtap
#1 Posted : Monday, May 16, 2011 12:16:14 PM(UTC)
dmtap
My GE Profile dishwasher model# PDW8980L OOSS does not drain. I have checked and cleaned evey hose and filter and have the proper 18" loop. Every cycle works except for draining. I can see the motor spinning and hear the water cleaning inside. When the pump cycle starts I can hear a slight hum by the pump. The motor is not spinning at that time. Should it be and how can I be sure which part is defective. Is the Actuator wax assembly involved with the draining cycle?
dmtap
#2 Posted : Tuesday, May 17, 2011 9:54:17 AM(UTC)
dmtap
It was the drain pump.
Joe / APP Team
#3 Posted : Tuesday, May 17, 2011 12:57:09 PM(UTC)
Joe / APP Team
DM,
Sounds like you have an inoperative, or jammed drain pump,
Part number: AP4412545
It is a separate component from the main wash/pump motor assembly.
and the wax actuator has no effect on the drain cycle,
Good Luck,
GE Dishwasher does not drain (Dishwasher Repair)
by JohnnyB 2/26/2010 10:25:25 AM(UTC)
