noclue
#1 Posted : Thursday, June 4, 2009 10:30:29 AM(UTC)
noclue
Yes i could sure use some help here with a pdf of my model or things to check for.Everything works fine but lost the heat on wash and dry cycles, no heat period.Wife also says been sticking on cycles not sure on that. Thanks and greetings from the rainy PNW.
#2 Posted : Friday, June 5, 2009 12:49:11 AM(UTC)
Replacement parts for FRIGIDAIRE FDP635RFR2 | AppliancePartsPros.com
Here is the tech sheet
http://manuals.frigidaire.com/p...df/Kinston/154296902.pdf
Check the element (10 ohms approx) and the Hi-Limit Thermostat (0 ohms)
noclue
#3 Posted : Tuesday, June 16, 2009 1:57:42 PM(UTC)
noclue
Denman
I have replaced element and still no heat wash or dry cycle.Could i jump the hi temp thermostat in heat cycle? i got a 0 ohm reading while disconnected.Reading on old heat element was 13.8 ohms on bench afraid i tested on 20k scale and got 0 ohms and ordered new one which is not the problem.Any help would sure be appreciated Thanks Denman
#4 Posted : Wednesday, June 17, 2009 5:25:43 AM(UTC)
Yes you could but I doubt it will make any difference as it measured 0 ohms at room temperature.
I would check the wires from the timer to the heater perhaps one of them is broken.
If the wires are OK then the most likely culprit is the timer.
The timer's heater contacts are probably shot.
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
