annemorris
#1 Posted : Thursday, April 30, 2009 9:04:20 AM(UTC)
annemorris
I gas oven will not heat up. When I set the Temp. it will not get warm or hot. For awhile it would heat up but very slowly, maybe close to an hour to get to 400! Now it doesn't heat up at all.
What part do we need (Igniter)?
Could we have a service guide and /:confused: or directions also please?
#2 Posted : Thursday, April 30, 2009 11:38:40 AM(UTC)
Remove the oven floor, the flame spreader and the bottom drawer. Locate the Bake igniter wire harness plug and unplug it. Check for 120VAC to the igniter while the control calls for Bake. If there is proper voltage then the igniter has to be replaced.
- The part number for the Bake igniter is AP4012072
Here are the breakdown diagrams and Replacement parts for JENN-AIR JGR8850ADB | AppliancePartsPros.com
Whirlpool Gas Oven will not heat up to desired temperature. (Oven Repair (including Ranges and Cooktops))
by captjob 7/29/2012 5:45:19 PM(UTC)
Ge Built-in Gas Oven Will Not Heat Up (Oven Repair (including Ranges and Cooktops))
by KWILLIS402 11/21/2008 9:44:05 AM(UTC)
