captjob
#1 Posted : Sunday, July 29, 2012 5:45:19 PM(UTC)
captjob
Hello,
I have a original builder model Whirlpool Oven that no longer reaches desired temperature. It takes an hour to reach 400 degrees and 45 minutes to reach 350. I already replaced the oven temperature sensor and it did not help.
Any other suggestions?
Captjob
ApplianceJunk
#2 Posted : Sunday, July 29, 2012 5:52:17 PM(UTC)
ApplianceJunk
Igniter is week and can't always light the oven when it calls for heat.
captjob
#3 Posted : Monday, July 30, 2012 8:47:12 AM(UTC)
captjob
OK thanks. I'll order another igniter.
Captjob
ApplianceJunk
#4 Posted : Monday, July 30, 2012 8:55:02 AM(UTC)
ApplianceJunk
You already replaced the igniter once before?
To test the igniter I would use a clamp on amp meter and see if it's in range with what is marked on the side of the gas valve.
