The broiler workers fine. When trying to start oven for baking. I set the temp & press start. It shows the selected temperature, then, after about 10 seconds shows 100 degrees. Nothing happens after that. Oven does not ignite. Oven worked perfectly yesterday. Today, won't start. What could have happened and what do I do to repair it?
Thanks in advance for any and all help. Happy Holidays. Keisha
I have the same problem with my built in oven. Upon investigating I believe I will need to remove the oven to connect the wires from the back. Did you have to get to it from the back? Did you replace your igniter? Did it fix the problem?
Thank you Rod
