jesco76
#1 Posted : Thursday, April 2, 2009 5:45:44 PM(UTC)
jesco76
Please help it won't spin!!!!!!!!!!!!!:confused:
#2 Posted : Friday, April 3, 2009 2:09:24 AM(UTC)
A Model Number might help.
Check the power at the plug with a meter.
Should be
L1 to L2 240 volts
L1 to Neutral and L2 to Neutral 120 volts
If you do not have a meter turn the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
Depending which half drops out, this can cause the motor to not run as it uses 120 volts.
If power OK, I would place a service call as the unit should still be under warranty.
If you mess with it you could void the warranty.
Samsung dryer won't spin (Dryer Repair)
by Guest 8/13/2023 2:50:03 PM(UTC)
DV448AEP/XAA Dryer Won't Spin (Dryer Repair)
by hufe1983 1/13/2020 4:48:55 PM(UTC)
After repair, dryer won't spin with clothes (Dryer Repair)
by skyledavis 8/9/2016 6:39:35 PM(UTC)
Dryer won't spin (Dryer Repair)
by Lovemydog 4/28/2015 6:40:21 AM(UTC)
GE dryer won't spin....except sometimes! (Dryer Repair)
by Cbee78704 11/29/2014 4:13:53 PM(UTC)
Kenmore Dryer won't spin (Dryer Repair)
by Connito 7/29/2014 5:59:09 AM(UTC)
Dryer won't spin fast (Dryer Repair)
by ezfreeze 8/2/2013 9:30:03 PM(UTC)
HELP! Dryer won't spin (Dryer Repair)
by askmelater 10/31/2012 12:43:09 PM(UTC)
Whirlpool Dryer won't spin (Dryer Repair)
by jumbo_rider 4/26/2011 6:24:22 PM(UTC)
Kenmore 98702 Stacked Washer/Dryer won't spin (Washer Repair)
by flashpipe 4/21/2011 5:31:40 AM(UTC)
by mtbikechick1 2/9/2010 3:28:08 PM(UTC)
Dryer Won't spin unless pushed by me (Dryer Repair)
by Rebillbula 4/4/2009 10:38:22 AM(UTC)
by Lingot 1/5/2009 7:19:10 PM(UTC)
by Peter H 11/11/2008 7:56:09 AM(UTC)
by LostinMS 8/17/2008 3:49:16 PM(UTC)
