tomastom
#1 Posted : Monday, July 18, 2011 7:32:23 PM(UTC)
tomastom
unbalanced load occurs in every wash cycle regardless of load size washer has been levelled and balanced any ideas?
Joe / APP Team
#2 Posted : Tuesday, July 19, 2011 5:57:32 AM(UTC)
Joe / APP Team
Tomastom,
Have you run a full,short cycle, with the washer empty ?
There are several possibilities, that would cause the UL code, and off balanced load. Improper loading, tub not floating properly, bad RPS assembly, etc. You may want to raise the top of the washer and check the suspension rods and joints for debris and stiffness.
Good Luck,
Whirlpool cabrio washer codes (Washer Repair)
by Guest 4/20/2024 11:59:12 AM(UTC)
Whirlpool Cabrio WTW6300SW1 (Washer Repair)
by Fieldsafo 2/12/2024 4:00:47 PM(UTC)
Whirlpool Cabrio Drum Mounting Hub replacement options (Washer Repair)
by Guest 5/8/2023 6:48:34 AM(UTC)
Whirlpool Cabrio - passes diags but wont initiate a cycle (Washer Repair)
by Jack Jolly 2/13/2023 9:20:45 AM(UTC)
Whirlpool Cabrio electric dryer model WED5800BW0 (Dryer Repair)
by thorning 9/26/2022 12:44:56 PM(UTC)
Whirlpool Cabrio washer water pressure too high in detergent dispenser (Washer Repair)
by dwprog 8/10/2022 11:52:58 AM(UTC)
Whirlpool Cabrio washer TWT8600 will not spin at the end of cycle (Washer Repair)
by ADK522JNRS 6/1/2022 5:53:35 AM(UTC)
Whirlpool Cabrio WTW6600SW2 drum will not balance (Washer Repair)
by Guest 5/28/2022 7:45:19 AM(UTC)
Whirlpool Cabrio Washer Stops Intermittently (Dishwasher Repair)
by Amadago76 4/1/2022 9:57:02 AM(UTC)
Whirlpool Cabrio (WTW6800WW1) (Washer Repair)
by jkernsjr 1/13/2022 1:01:50 PM(UTC)
Whirlpool CabrioWTW5800BC0 (Dryer Repair)
by Juiceboi01 12/19/2021 8:09:03 PM(UTC)
Whirlpool Cabrio Washing Machine replaced transmission (Washer Repair)
by reggiebliss 8/26/2021 7:31:39 PM(UTC)
Whirlpool cabrio won't spin out (Washer Repair)
by Guest 7/28/2021 7:22:56 AM(UTC)
Whirlpool Cabrio Washer banging noise at the spin cycle (Washer Repair)
by Guest 5/13/2021 2:33:38 PM(UTC)
Whirlpool cabrio washer won’t final spin (Washer Repair)
by Guest 3/20/2021 8:31:43 PM(UTC)
