thorning
#1 Posted : Monday, September 26, 2022 12:44:56 PM(UTC)
thorning
the above dryer with s/n M44483058 was given to me for possible repair. It will not start or heat. I checked all of the thermostats and belt switch and heater coil and found no problems, When I try to get it to turn on it makes a slight click in the control panel but nothing else. I cant get it to go into the diagnostic mode or show a code. All of the indicator lights work. I suspect the control panel as the problem area but need help to define the problem area if at all possible. Can anyone help on this one.? It is very clean and shows no problems anywhere but will not start.
thorning
#2 Posted : Tuesday, September 27, 2022 7:41:45 AM(UTC)
thorning
The main circuit was removed and a bad solder joint was found under the motor relay . This was repaired and the unit now works properly.
