segallis
#1 Posted : Tuesday, March 29, 2011 8:15:15 PM(UTC)
segallis
UPDATE: I found a bad part - the starting relay had what looks like a ceramic disk with metal on the surface that was in pieces. Cap measures good. I am curious how that relayand disk are designed to work though. With the disk in pieces it looks like the line will still reach the run coil of the compressor. And the start coil will receive an out of phase voltage through the cap. Is the disk supposed to short the two terminals on a cold start and then open up once its running, or does it start as an open on a cold start and then short the terminals.
Also, my run coild is about 4 ohms and my start coil is about 8 ohms. Is this ok or should they be identical? It's an Embraco EGY90HLP.
-Greg
OLD POST:
My fridge/freezer isn't cold. Looks like it was "running" most of the day while I was at work but no cooling. Fan is running and compressor was very hot to the touch (so I'm guessing the relays are fine) but I could not hear the typical compressor hum, and there was no heat on any of the freon tubes.
I'm suspecting the starting/run capacitor may be shot (this happened to my A/C compressor last year).
How common is a cap failure?
Is it a starting cap or a run cap on these compressors?
How long can a compressor survive powered but not actually pumping? Thanks,
-Greg
Whirlpool Fridge odor (Refrigerator & Freezer Repair)
by Guest 5/14/2024 4:46:42 AM(UTC)
Whirlpool Fridge wrf736sdaw14 (Refrigerator & Freezer Repair)
by wolfpackchic 1/7/2024 12:19:24 PM(UTC)
Whirlpool Fridge GX5SHDXVA00 - Fridge Fine; Freezer Too Warm (Refrigerator & Freezer Repair)
by FamineLD 8/21/2023 4:54:57 AM(UTC)
Whirlpool fridge leaking, front left bottom, only when dispensing water? (Refrigerator & Freezer Repair)
by TwinTurbo95 11/11/2022 8:18:07 AM(UTC)
Whirlpool fridge beeps when dispensing water and the Order Filter light is on (Refrigerator & Freezer Repair)
by Guest 8/27/2022 7:06:18 PM(UTC)
Release button on Whirlpool Fridge Stuck and can't get ice bin out (Refrigerator & Freezer Repair)
by Decijp3 7/15/2022 8:03:20 PM(UTC)
Whirlpool fridge WRF736SDAM13 (Refrigerator & Freezer Repair)
by Tinker69 4/8/2022 6:44:31 AM(UTC)
Whirlpool fridge model wrs325fdab02 (Refrigerator & Freezer Repair)
by Guest 3/30/2022 9:55:14 PM(UTC)
Whirlpool fridge making a new sound and struggling to make ice (Refrigerator & Freezer Repair)
by randyros@gmail.com 1/21/2022 6:59:23 AM(UTC)
Whirlpool Fridge Just Shuts Down Model WRF767SDEM01 (Refrigerator & Freezer Repair)
by Guest 10/12/2021 10:51:41 AM(UTC)
Whirlpool Fridge gets NO power (Refrigerator & Freezer Repair)
by csdarrigo 7/27/2021 4:15:03 PM(UTC)
Compressor for Whirlpool Fridge (Refrigerator & Freezer Repair)
by topgunny 6/7/2021 5:13:20 PM(UTC)
Whirlpool fridge water leak not solvable with ptrap (Refrigerator & Freezer Repair)
by richdell 5/2/2021 5:33:45 AM(UTC)
Whirlpool Fridge not dispensing water intermittently, ice dispenser is fine. (Refrigerator & Freezer Repair)
by dscheste 4/27/2021 6:41:29 AM(UTC)
whirlpool fridge ed5shaxml 12 (Refrigerator & Freezer Repair)
by tomok 3/8/2021 10:25:13 AM(UTC)
