jseaward
#1 Posted : Monday, March 14, 2011 8:37:23 AM(UTC)
jseaward
I bought a house that had the microwave installed above the range. It has a vent button but when I activate the vent it does run but does not draw the steam from the pots on the stove. I removed the filters on the bottom of the device but I cannot see any fans. All I see is a gray metal bottom that does not appear to be the type of microwave you place over a stove. My question is ; is model MHE14XMB-3, serial no. S 4128957, maufactured 10/05- is this a microwave built to be installed over a range to draw the steam up the roof vent?
magician59
#2 Posted : Monday, March 14, 2011 8:54:06 AM(UTC)
magician59
Yes. This is a microwave/vent hood combination. Check to see if the grease filter is clogged or restricted. This is very common.
Part number: AP4299743
GE PT7800SHASS Combination Microwave / Oven - Key Panel SHORTED (Oven Repair (including Ranges and Cooktops))
by RCAppl 4/23/2024 7:59:18 AM(UTC)
GE Oven - Microwave/Oven PT7800SH2SSA (Oven Repair (including Ranges and Cooktops))
by Guest 2/13/2024 11:22:12 AM(UTC)
Kenmore Pizza Oven Microwave (Microwave Repair)
by mwjkmail 2/3/2024 5:10:49 PM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Whirlpool Microwave Lower Bulb will not turn on (WMH31017HS08) (Microwave Repair)
by Axtell 1/2/2024 3:49:44 PM(UTC)
Kitchen aid electric wall microwave and oven (Microwave Repair)
by Guest 11/9/2023 8:15:09 AM(UTC)
Frigidaire Microwave PLMVZ169HCA (Microwave Repair)
by Guest 10/25/2023 11:02:01 AM(UTC)
KitcheAid Microwave/Oven Wall Combo KOCE500ESS05 Error Code F6E8 (Microwave Repair)
by tjperlman 10/19/2023 10:07:59 PM(UTC)
Microwave Advantium 120 display blank (Microwave Repair)
by tod.colbert@gmail.com 8/6/2023 9:13:49 AM(UTC)
Litton model 1800 microwave (Microwave Repair)
by Guest 7/14/2023 7:08:12 PM(UTC)
Microwave touchpad (Microwave Repair)
by duguyisheng 7/6/2023 5:12:28 PM(UTC)
Over range Microwave exhaust fan slows (Microwave Repair)
by Mmetzinger 6/3/2023 7:19:23 AM(UTC)
Dim Light on Microwave (Microwave Repair)
by Guest 5/15/2023 8:31:44 AM(UTC)
Kitchenaid kbms1454bbl microwave (Microwave Repair)
by Guest 4/1/2023 10:24:42 AM(UTC)
Microwave Parts Cannot Be Returned and Microwave Still Has The Problem (Microwave Repair)
by atlantic 3/31/2023 12:42:43 PM(UTC)
