nicorock2003
#1 Posted : Monday, February 14, 2011 8:32:59 AM(UTC)
nicorock2003
Having problems with the dryer cycle, the timer will work and dry proper when set on a timed cycle, however on the other cycle that goes from "More Dry to the Finish setting" the dial knob does not move. The timer dial stays in one spot until it is turned off manually.
Jeff / APP Team
#2 Posted : Tuesday, February 15, 2011 7:24:13 AM(UTC)
Jeff / APP Team
The first thing you need to check is your vent system. Make sure that it is clear from all lint. Poor venting can cause the dryer not to work properly on sensor dry. If all is clear then you will need to replace the timer.Part number: AP2042594
Kenmore 665.17032403 Doesn't cycle to the heated dry cycle (Dishwasher Repair)
by breckrider 5/10/2023 8:01:43 AM(UTC)
Running 2 dry cycles per load (Dryer Repair)
by Jrepman 7/23/2017 7:47:02 AM(UTC)
Low wash temp, dry cycle works fine (Dishwasher Repair)
by eblau 4/15/2017 4:39:41 AM(UTC)
Automatic Dry cycle not advancing (Dryer Repair)
by Island Anni 9/14/2016 12:35:21 PM(UTC)
Burner keeps going thru whole dry cycle (Dryer Repair)
by 383magnum 8/12/2016 8:56:00 AM(UTC)
Dry cycle to hot? (Dishwasher Repair)
by saschneider 6/6/2015 11:02:49 AM(UTC)
dryer does not finish dry cycle and quits spinning (Dryer Repair)
by asthomp 2/19/2014 3:53:14 PM(UTC)
Dryer only runs on 15 min air dry cycle (Dryer Repair)
by pschell 8/26/2013 2:56:06 PM(UTC)
whirlpool gas dryer will only turn on in air dry cycle. (Dryer Repair)
by hungeeee 6/20/2012 3:12:56 PM(UTC)
Dishwasher Heat Dry/Air Dry Cycle (Dishwasher Repair)
by bcfapplicance 3/21/2012 12:43:05 PM(UTC)
Whirlpool Dryer Automatic Dry Cycle not working (Dryer Repair)
by christyhecht 7/28/2011 9:09:13 AM(UTC)
maytag lsg7806aae shuts off on timed cycle but not custom dry cycle? (Dryer Repair)
by pullinin 7/14/2011 1:24:45 PM(UTC)
Washer drains all water but clothes are wet after spin dry cycle (Washer Repair)
by sally57 4/19/2011 7:05:04 AM(UTC)
Dryer will not stop running in timed dry cycle (Dryer Repair)
by Rhonda Toney 3/30/2011 3:56:32 PM(UTC)
No heat on dry cycle (Dishwasher Repair)
by tommy.devillier 7/26/2010 1:12:52 PM(UTC)
