AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
whirlpool gas dryer will only turn on in air dry cycle.
My dryer stopped heating last week, after checking everything out it came down to one of the coils being bad. I replaced both coils put everything together and now the dryer only turns on in air dry/cool down cycle. Can anybody help me out??? The dryer would work in all the cycles before i changed the coils. The symptoms I was having before is that the ignitor would light up put there was no gas from from the gas valve. I checked the coils with a ohm meter and the first coil was bad so thats why i changed both coils. I just find it weird that the dryer only works in that cycle and not in any other cycle. I also checked the timer and its good.
How did you disassemble the dryer for the repair you did? Which parts did you remove?
Dryer Repair
