oneida
#1 Posted : Tuesday, January 25, 2011 6:48:29 PM(UTC)
oneida
I have a problem when you go to start the only light that comes on is the normal wash and just blinks will not start any suggestions
#2 Posted : Wednesday, January 26, 2011 12:59:46 AM(UTC)
Replacement parts for KENMORE 66513819K600 | AppliancePartsPros.com
If you need a parts breakdown there should be on Sears Parts site.
Here is the tech sheet, see the attachment.
Try running the diagnostics to see if any additional clues to the cause come up.
A blinking light is often a shorted key.
This could be the keypad or the control pad.
The keypad keys have to be checked with a meter.
If it checks out OK then I would replace the control board.
Still a bit of a crap shoot but your odds are better.
File Attachment(s):
13819K600.pdf (251kb) downloaded 6 time(s).
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest Yesterday at 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
