Just replaced water level switch on Whirpool washer (LSR8233JQ0) and that works fine now. But the timer worked fine before I replaced the water level switch and now it just hums after the washer is filled with water. Is it possible that a connection got loose for the timer while getting the old water level switch out and the new one in? What do you think guys? Thanks.
Originally Posted by: cheryl54 ...Is it possible that a connection got loose for the timer while getting the old water level switch out and the new one in?... Everything is possible. Just open the control panel and double check all connections. :) Gene.
