titoac
#1 Posted : Wednesday, May 27, 2009 4:45:38 PM(UTC)
titoac
The machine does not work on high or medium load cycle. Does not work on Normal load. Only works on Sport/Low. It also does not work on Hot/cold or warm/warm water.
sidfink43
#2 Posted : Friday, May 29, 2009 11:26:43 AM(UTC)
sidfink43
Given that all of these function come out through the central control unit, I would suggest that the CCU board is your problem.
Unfortunately, this is an expensive part, and I cannot guarantee that this will fix it, but it is highly likely.
The replacement is fairly easy if you want to do it. Here is your part.
Part Details - FRIGIDAIRE CONTROL BOARD, part number: 137005000
Good luck and let us know what you decide to do and how it turns out.
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
