Has ANYONE found diag. manuals on a Bosch SHE4AM? Mine is acting up. To begin with the arms were not getting enough pressure to rotate. So I took it apart, pump and all thinking food had been stuck in pump. Wrong! It is getting enough water in the washer. Now the bottom arm is spraying fine but the top arm and sprayer at very top is still not getting enough pressure. Any help would be GREAT!! Thank you in advance.
