rrg1965
#1 Posted : Monday, March 3, 2014 9:37:12 AM(UTC)
rrg1965
I have this problem with my electric oven. Broil is working but not the Bake function. New element was put in but still not working. No 240V output going to the Red/Yellow terminals of the Bake Element. You think it could be the control board or Relay Board is the issue here? I heard clicking sound of relays at the back of the controller. Can I get a schematic diagram if you have for this model?
Thanks.
#2 Posted : Tuesday, March 4, 2014 1:36:04 AM(UTC)
Parts for Maytag MER5775QCS Range - AppliancePartsPros.com
Odds are that the control board is shot.
This unit does not have a separate relay board.
I am assuming that the oven stays in pre-heat and does not show that it is ready.
File Attachment(s):
MER5775.pdf (316kb) downloaded 4 time(s).
GE Hotpoint Stove Bake Element not working (Oven Repair (including Ranges and Cooktops))
by Guest 3/21/2023 10:17:36 AM(UTC)
Bake Element not working everything else fine (Oven Repair (including Ranges and Cooktops))
by DBLTRAUMA 12/31/2016 5:24:27 AM(UTC)
Bake element not working in double oven (Oven Repair (including Ranges and Cooktops))
by luck11 1/11/2015 7:45:26 AM(UTC)
Bake element not working (Oven Repair (including Ranges and Cooktops))
Belarus mcclelland 1/10/2015 12:20:06 PM(UTC)
Frigidaire wall oven, bake element not working (Oven Repair (including Ranges and Cooktops))
by Fred V 10/30/2013 5:59:41 PM(UTC)
Bake element not working. Thermostat or Controller board? (Oven Repair (including Ranges and Cooktops))
by leorosi 5/12/2013 4:40:07 PM(UTC)
by clwcomp 7/17/2012 9:06:35 AM(UTC)
Bottom bake element not working (Oven Repair (including Ranges and Cooktops))
by oldmill 6/2/2012 7:56:34 AM(UTC)
GE oven bake element not working, broil works. (Oven Repair (including Ranges and Cooktops))
by HelpMeAnyone 12/25/2011 3:39:09 PM(UTC)
Oven Bake element not working (Oven Repair (including Ranges and Cooktops))
by NickJade 11/14/2011 8:17:42 AM(UTC)
by apps2777 5/26/2011 8:56:52 AM(UTC)
by rfridley1 2/22/2011 6:45:27 AM(UTC)
Replacement bake element not working (Oven Repair (including Ranges and Cooktops))
by Bex291 1/12/2011 5:53:48 PM(UTC)
Bake element not working - Broil is fine. (Oven Repair (including Ranges and Cooktops))
by dank_01 3/10/2010 8:21:05 PM(UTC)
Wall oven bake element not working! Broil works, clock works. (Oven Repair (including Ranges and Cooktops))
by ajachyra 12/1/2009 1:37:54 PM(UTC)
