The refrigerator sounds like it wants to come on and then there is a single "click" and nothing at all happens after that. Any ideas? Or is it too far gone to worry about:confused: This unit could be over 10 yrs old. The model number is missing part of it from what it looks like from other posts but that is the only info I can find inside the door. I still would like to hear from you on this issue if possible. The fan is very hard to turn by hand also. So I am not sure if that is a problem also. We sprayed it w/ WD40 and it loosened up a little bit but it might have frozen up.
