morgangjs
#1 Posted : Monday, April 20, 2009 3:41:49 PM(UTC)
morgangjs
washer fills, agitates, cycles through the wash and stops at the draining stage, also no spin stage
Drags1998
#2 Posted : Monday, April 20, 2009 4:07:18 PM(UTC)
Drags1998
Check the LID-SWITCH!!!
applianceman
#3 Posted : Monday, April 20, 2009 4:09:49 PM(UTC)
applianceman
The lid switch is the most common cause for this. To check the lid switch, first unplug the washer. Then you need to take out the two screws that hold the control panel in place (one on each side, you may be able to see them in front, you may have to snap off two covers to see them or they may be on the back) then hinge the control panel up. Once its up, you should see a plug attached to the case with three wires - unplug it. Now using your ohmmeter, check to see if you have continuity between the two outside wires (make sure the lid is closed) on the female plug end (the one still attached to the case after you have unplugged it). It you do not have continuity; the lid switch is bad and needs replacing. Whirlpool Washer Not Spinning Repair Guide
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
Recommended replacement for WP22001311 Maytag Washing Machine Unbalance lever (Washer Repair)
by Guest 4/29/2023 12:17:37 PM(UTC)
Whirlpool washing machine drive hub (Washer Repair)
by Guest 4/23/2023 7:29:26 AM(UTC)
