RLPOWELL
#1 Posted : Tuesday, January 22, 2013 3:23:28 PM(UTC)
RLPOWELL
Water was running from underneath the machine and my husband took it apart and found two of the hoses had holes in them. He replaced both hoses and put it back together. When we ran a load of clothes the water did not spin out. Can you tell us what could be causing this?
Thnx,
Ruby
#2 Posted : Wednesday, January 23, 2013 1:33:28 PM(UTC)
Hi Ruby,
What are the part numbers of the hoses your husband installed?
Remove the front panel and check if the drain pump works when the washer should drain.
Post the results.
Here are the breakdown diagrams and Parts for Frigidaire GLWS1339ES1 Washer - AppliancePartsPros.com
washer jumping around (Washer Repair)
by Guest Today at 4:57:03 AM(UTC)
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg Yesterday at 6:29:18 AM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Glass washer not heating up (Dryer Repair)
by Guest 5/15/2024 7:52:01 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
Speed Queen top load washer model AWN412SP111TW01 (Washer Repair)
by Guest 4/28/2024 6:36:53 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
