Kitchen aid front loader washing machine will not spin. Makes humming noise only.
Look under the top cover or inside the lower service panel and you should find some tech notes that will tell you how to do some diagnosis.
Also, when you take off the lower service panel check the pump and drain hoses for an obstruction.
