stankiewicz93
#1 Posted : Wednesday, August 3, 2011 1:12:32 PM(UTC)
stankiewicz93
I have A Whirlpool Cabrio Washer and whenever it goes in to the spin cycle , it starts banging and I get an error code UL not sure which parts i need to fix it .
sidfink43
#2 Posted : Thursday, August 4, 2011 6:03:32 PM(UTC)
sidfink43
Under the top of the machine is a tech sheet which will tell you how to run some tests.
UL is an unbalanced load indicator, which in this model may indicate a whole lot of things that may or may not be related to an unbalanced load.
Try to use the diagnostics in in the tech sheet to narrow things down.
newj
#3 Posted : Thursday, December 22, 2011 9:09:24 AM(UTC)
newj
I'm having the same problem as stankiewicz93. If I move the clothes around after I get the uL error code it sometimes solves the problem. Sometimes I have to rebalance the load several times before the machine will complete its cycle. Even if I only put a few pieces of clothing in the machine it will still do this. I ran the built in diagnostics and the F32 and F51 codes were stored in memory. It seems that there is something mechanical (spring or mount) that allows the tank to move around too much. How can an electronic problem like F51 allow the tank to move around too much?
NEWJ :confused:
Cant remove Samsung ice bin , need help please (Refrigerator & Freezer Repair)
by Orlando123 4/20/2024 10:55:35 AM(UTC)
help maytag comercial dryer (Dryer Repair)
by blackwell316 4/4/2024 5:05:48 PM(UTC)
HELP!!! Maytag Lat9604abe leaking from weeping holes in tub seal (Washer Repair)
by gocanada72 3/18/2024 5:53:29 AM(UTC)
GE Frontload Washer - Trouble Shooting Help (Washer Repair)
by mahgnibb 3/14/2024 2:37:10 PM(UTC)
Help finding the right screws to secure the top panel. (Washer Repair)
by mikkel3906z 2/20/2024 12:30:41 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Washer help please maytag (Washer Repair)
by Guest 12/13/2023 4:45:08 AM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
HELP - Washer randomly pauses during cycle (Washer Repair)
by Guest 11/9/2023 11:06:57 AM(UTC)
Help! Washer chirping noise (Washer Repair)
by Guest 10/8/2023 6:40:46 AM(UTC)
Need help with failed display (Microwave Repair)
by Guest 8/6/2023 9:04:42 AM(UTC)
Troubleshooting Help!! (Dishwasher Repair)
by Guest 6/20/2023 1:14:28 PM(UTC)
Need help with cut in cut out Old McQuay freezer w/Hupp compressor (Refrigerator & Freezer Repair)
by Deserttoad 5/5/2023 2:39:37 PM(UTC)
Kenmore Dryer, Help! (Dryer Repair)
by C DeBardeleben 4/18/2023 3:58:41 PM(UTC)
