4 Pages«<234
#31 Posted : Wednesday, December 10, 2008 10:17:54 AM(UTC)
Hi Ray,
Before you'll make the final decision perform all tests recommended in the tech sheets attached to this reply.
File Attachment(s):
Oasis tech sheets.pdf (306kb) downloaded 78 time(s).
Ray052104
#32 Posted : Thursday, December 11, 2008 5:43:44 AM(UTC)
Ray052104
Hey Gene,
Thanks for the info. The tech sheet says to use test 4 if you are getting an f2 code. The test says it is if you do not see lights or hear beeps. When I plug in the washer about half the lights flash and the machine does beep, all while I am getting the f2 code. any sugestions?
Ray
#33 Posted : Thursday, December 11, 2008 8:07:21 AM(UTC)
Ray,
Double check all connections and if it would not help then probably the user interface has gone bad.
Bill Stanley
#34 Posted : Saturday, December 18, 2010 5:56:38 AM(UTC)
Bill Stanley
Gene, I have read so many post and some are old...can you please tell me the correct part number to fix the F1 error on a Sears Oasis Elite, Mod 110.27032603. We get the error on every single load that is washed with 21 minutes left in the cycle. I have been jerked around so much by Sear I am going to repair it myself. Is the part listed on APP (AP4360738) the correct one? You can reply to this directly or my personal email: wcstanley@cox.net.
Thanks!
Bill
#35 Posted : Sunday, December 19, 2010 2:45:33 PM(UTC)
Yes Bill. The part number you posted is the correct part number.
Bill Stanley
#36 Posted : Saturday, December 25, 2010 9:43:44 AM(UTC)
Bill Stanley
Thanks Gene. I order the part, it came in very quicky. It was easy to replace and works like a champ! Now, when it rains it pours. My dryer, model 110.67042600, seems to get stuck in the cycle with 18-20 minutes remaining. Is there a tech sheet with any automatic tests like the washer has? I performed the same steps to auto start and it does just like the washer (with 88 showing), but nothing else. Please advise.
Bill
#37 Posted : Wednesday, December 29, 2010 10:29:44 PM(UTC)
Originally Posted by: Bill Stanley Go to Quoted Post
...seems to get stuck in the cycle with 18-20 minutes remaining...
...Is there a tech sheet with any automatic tests like the washer has?...
Bill,
I'm glad to hear the washer is back in business.
Does the dryer stop completely at this point or it's just the timer not advancing? Did it show any error code?
The tech sheet suppose to be inside the console.
Kenmore Oasis Elite heat issue (Dryer Repair)
by dkessinger 5/5/2015 12:43:24 PM(UTC)
Kenmore Oasis Washer F1 code (Washer Repair)
by sofedup 1/2/2012 8:18:51 AM(UTC)
Kenmore Oasis--loud spin cycle--water pressure? (Washer Repair)
by love2box 12/23/2011 12:07:52 PM(UTC)
Kenmore Oasis noisy when filling (Washer Repair)
by Reedster 12/6/2011 1:40:53 PM(UTC)
Kenmore Oasis Washer F68 (Washer Repair)
by chikag 10/5/2011 4:16:46 PM(UTC)
kenmore oasis washer (Washer Repair)
by craymomtls@aol.com 8/28/2011 4:58:34 AM(UTC)
Kenmore Oasis Washer Error Code F51 (Washer Repair)
by g5d9s 8/17/2011 9:23:23 AM(UTC)
Kenmore Oasis Elite HE (Washer Repair)
by JTA 7/27/2011 6:54:48 AM(UTC)
kenmore oasis cant find model or serial # (Washer Repair)
by jj20375 6/29/2011 1:51:17 PM(UTC)
Kenmore Oasis Turns on by itself/beeps/arbitrarily changes settings (Washer Repair)
by kingirp 2/15/2011 8:37:44 AM(UTC)
kenmore oasis dying (Washer Repair)
by ferg431 1/30/2010 5:28:42 PM(UTC)
Kenmore Oasis Washer (Washer Repair)
by dwalker4 1/14/2010 2:45:17 PM(UTC)
Kenmore Oasis 27032600 Power Problem (Washer Repair)
by nylabor 10/31/2009 1:58:01 PM(UTC)
kenmore oasis lid does not lock (Washer Repair)
by wgb123 9/30/2009 7:24:22 AM(UTC)
kenmore oasis he fault code F50 (Washer Repair)
by end of the road gang 9/13/2009 7:51:11 AM(UTC)
4 Pages«<234
