selphstephanie
#1 Posted : Monday, February 7, 2011 6:55:39 PM(UTC)
selphstephanie
The little fan-shaped part that crushes the ice broke us into pieces and was dispensed with my ice and eventually the ice maker stopped making ice all together. The water side NEVER stopped coming out.
:mad:
#2 Posted : Tuesday, February 8, 2011 6:18:14 PM(UTC)
Hi Stephanie,
I'm afraid I did not get clear which part in the ice crusher broke. Can you refer to the diagram using the reference number please?
When you said "...the ice maker stopped making ice..." did you mean the ice maker itself or the ice dispenser which dispensing the ice through the door?
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL KSRD22FKSS15 REFRIGERATOR | AppliancePartsPros.com
selphstephanie
#3 Posted : Tuesday, February 8, 2011 6:23:42 PM(UTC)
selphstephanie
Part #28- the fan-shaped thing inside the ice container started coming out WITH ice but after it did that, ice stopped coming from the ice tray due to NO water going into the tray. We do get water form the dispenser though.
selphstephanie
#4 Posted : Tuesday, February 8, 2011 6:31:15 PM(UTC)
selphstephanie
Mr. Gene, it may even be part # 27 because it's on the inside of the container at the end where the ice drops directly into your glass also crushing it- it's that particular blade or blades that are broken off.
selphstephanie
#5 Posted : Tuesday, February 8, 2011 6:58:44 PM(UTC)
selphstephanie
Mr. Gene, I realized that it's the Auger. I have ordered the part. I also need to know what is the reason that water will not pour into my ice tray. Is it the pump or the solenoid valve that prevents the water from going through.
#6 Posted : Tuesday, February 8, 2011 7:33:00 PM(UTC)
check in what position is the ice maker shut off arm (#31 on the diagram).
If it is down then the ice maker is turned on.
selphstephanie
#7 Posted : Wednesday, February 9, 2011 7:06:01 PM(UTC)
selphstephanie
We always left the lever down so that it would keep making ice. It just stopped receiving water in the ice cube tray...
#8 Posted : Thursday, February 10, 2011 4:39:25 PM(UTC)
Hi Stephanie,
Locate the water inlet valve on the back of the refrigerator. Swap the wires between the green and red solenoids. The terminals are different in size, so use some extra insulated wires to make a good connections.
Push the water dispenser lever for a few seconds and check if there is some water in the the maker.
If there is no water, check the water feeding tube into the ice maker for any blockage. If the tube is clear, replace the water inlet valve.
- The water inlet valve Part number: AP3160649
Lg ice maker leaking (Refrigerator & Freezer Repair)
by Guest 4/10/2024 2:58:55 PM(UTC)
KITCHEN AID UNDERCOUNTER ICE MAKER KUIC18NNZS0 (Refrigerator & Freezer Repair)
by kwhowell6539 3/25/2024 1:49:40 PM(UTC)
Ice maker slabbing (Refrigerator & Freezer Repair)
by Guest 3/11/2024 8:34:02 PM(UTC)
Frigidaire Freezer FPFU19F8WF4 - ice maker problem (Refrigerator & Freezer Repair)
by Eric8888 3/5/2024 11:02:19 AM(UTC)
Installing ice maker, looking for holes (Refrigerator & Freezer Repair)
by Grendel25 2/16/2024 10:02:12 AM(UTC)
ice maker in LG fridge model #LFX31925st/08 (Dishwasher Repair)
by diohabla 2/16/2024 8:36:50 AM(UTC)
Freezer holding at 22 degrees and ice maker (located in refrigerator cabin) isn't working (Refrigerator & Freezer Repair)
by eric5605 2/13/2024 4:35:48 AM(UTC)
Ice maker fiil/dump (Refrigerator & Freezer Repair)
by Guest 2/12/2024 5:46:50 AM(UTC)
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw 2/9/2024 8:35:22 AM(UTC)
Ice maker issues and more? LG LFX25971 (Refrigerator & Freezer Repair)
by turtlejay 2/1/2024 5:07:00 PM(UTC)
LG French Door can the lower craft ice maker be swapped to cubed? (Refrigerator & Freezer Repair)
by Bstewart63 1/3/2024 11:45:50 AM(UTC)
Whirlpool Gold Side by Side (GSS26C4XXF03/HR14386344) Door Ice Maker Troubleshooting (Refrigerator & Freezer Repair)
by ForumUser1 12/25/2023 11:44:03 AM(UTC)
Need service code to defrost Electrolux ice maker, EI23BC56ISB (Refrigerator & Freezer Repair)
by Guest 12/16/2023 12:29:49 PM(UTC)
Wiring harness clip KitchenAid freestanding ice maker KUIC18NNZS0 (Appliance Parts)
by GADIY 12/5/2023 12:02:09 PM(UTC)
Ice Maker Arm trapped down, started to flood, Now won't work... help (Refrigerator & Freezer Repair)
by jimtmcdaniels 12/5/2023 7:20:56 AM(UTC)
