dorismcdowell
#1 Posted : Thursday, September 2, 2010 12:38:41 PM(UTC)
dorismcdowell
washer fill up with water but will not wash
dorismcdowell
#2 Posted : Thursday, September 2, 2010 12:45:36 PM(UTC)
dorismcdowell
fiil up with water but will not wash
dorismcdowell
#3 Posted : Thursday, September 2, 2010 12:55:01 PM(UTC)
dorismcdowell
dorismcdowell
#4 Posted : Thursday, September 2, 2010 1:00:56 PM(UTC)
dorismcdowell
Ihave a GE washer it will fill up with water but it will not wash
#5 Posted : Thursday, September 2, 2010 4:12:41 PM(UTC)
Remove the front panel and check the in line operational fuse for continuity. The fuse location is shown in the attached file.
If the fuse is fine, check the status of the motor green indicator light and post the results.
- The fuse link Part number: AP4380189
Here are the breakdown diagrams and Replacement parts for General Electric WHDRR418G0WW Washer | AppliancePartsPros.com
P.S. I understand you are starving for your washer but multiple posts in the same thread would not do any good for you because it looks for other people like someone else already replied with a fix to the problem.
File Attachment(s):
Fuse location and diagram.doc (238kb) downloaded 5 time(s).
The signal LED location.doc (541kb) downloaded 4 time(s).
Top load - unit disassembly.doc (629kb) downloaded 3 time(s).
Kenmore 90 Series top-loader washer won't agitate/drain/spin (fixed?) and makes metallic noise (Washer Repair)
by deepdiver359 Yesterday at 8:09:21 PM(UTC)
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
washer jumping around (Washer Repair)
by Guest 5/19/2024 4:57:03 AM(UTC)
Kenmore Washer Hums and Won't spin (Washer Repair)
by dieselgg 5/18/2024 6:29:18 AM(UTC)
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Glass washer not heating up (Dryer Repair)
by Guest 5/15/2024 7:52:01 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Vintage Maytag washer A612 motor replacement - possible to use single speed motor? (Washer Repair)
by mookie3333 5/3/2024 5:58:32 PM(UTC)
Amana top load washer model NTW4600 (Washer Repair)
by Guest 5/2/2024 8:47:15 AM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
Amana washer load like a flying airplane (Washer Repair)
by wilsonjiaho 4/30/2024 1:48:54 PM(UTC)
Frigidaire max load top load washer (Washer Repair)
by Guest 4/29/2024 9:02:43 AM(UTC)
