rrollins
#1 Posted : Tuesday, June 22, 2010 2:03:45 PM(UTC)
rrollins
Dishwasher doesn't completely drain? I checked the drain hose but it is clear. I need help!
revndave
#2 Posted : Tuesday, June 22, 2010 2:27:53 PM(UTC)
revndave
Check air gap,kink in drainline.
revndave
#3 Posted : Tuesday, June 22, 2010 2:30:29 PM(UTC)
revndave
Piston may be worn out
http://www.appliancepartspros.com/PartImage.aspx?imgid=Z3BqLjBfbXNfODEwMDFYNDJEVy9IRUcvc290b2hwdHJhcC8%3d
Located in rear of tank under screen.4 screws hold it on.
#4 Posted : Wednesday, June 23, 2010 2:23:43 AM(UTC)
Your model number is short a number of digitd so I used GSD5940D00SS.
Here are your parts.
Replacement parts for General Electric GSD5940D00SS Dishwasher | AppliancePartsPros.com
First I would remove the sump cover (center bottom of tub) and check that it is empty and nothing is wrapped around the chopper. Be careful as there is often broken glass in the sump. Also take note of how the insert goes in, put it in wrong and the chopper will eat it.
Usually you will also see poor wash results.
Next would be the Piston & Nut (Item 564 in Section 2) as suggested by revndave.
It is under the screen filter at the back/bottom of the tub.
It unscrews.
Check that is seals correctly.
If it does not seal during the drain cycle some of tthe water is directed back into the tub instead of out the drain hose.
This is a very common problem.
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest 5/17/2024 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
