slovanPA
#1 Posted : Monday, January 11, 2010 6:59:31 AM(UTC)
slovanPA
I beleive my timer is inoperable on my dryer. I have the timer and the auto dry on one dial. when I select the dial to a time it does not move. When i use the auto dry feature it does not turn either. before i order a new timer, i wanted to ensure it was not something else first. This seems like a no brainer, however, i keep getting a nagging feeling that it may be some type of sensor also.
Thank you,
mike
#2 Posted : Monday, January 11, 2010 11:56:28 AM(UTC)
Replacement parts for MED5700TQ0 models | AppliancePartsPros.com
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208578889.pdf
Yes, when the timer does not advance in both Auto and Timed modes it is usually the timer that is shot.
A way to be sure is to measure the voltage across the timer motor, if you have 120 volts and it does not advance the timer is toast.
Be careful, there is 240 volts in the timer area and it can be lethal !!!
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Dryer Timer Humming (Dryer Repair)
by terzolino 4/6/2023 10:18:16 AM(UTC)
Kenmore Dryer Timer Power Resistor Rating (Dryer Repair)
by mhall264 3/19/2021 9:04:39 AM(UTC)
Dryer timer shorting - help me verify my rationale (Dryer Repair)
by jeromio 1/29/2020 6:51:31 PM(UTC)
Whirlpool dryer timer knob (Dryer Repair)
by robertjhebert 10/27/2019 8:50:18 AM(UTC)
Kenmore dryer timer or no timer (Dryer Repair)
by Jester1x 10/25/2019 8:47:13 PM(UTC)
Whirlpool dryer timer won't stop running. (Dryer Repair)
by ppipowerclass 4/2/2018 2:18:22 PM(UTC)
Wiring Help On GE Dryer Timer (Dryer Repair)
by Kierancypher 6/16/2017 11:00:27 AM(UTC)
Dryer Timer Compatibility (Dryer Repair)
by Paulvolter 5/28/2017 6:48:02 PM(UTC)
dryer timer release brackets (Dryer Repair)
by lcolquitt 5/24/2017 2:50:20 PM(UTC)
Kenmore Gas Dryer Timer (Dryer Repair)
by keepitfromthedump 5/24/2017 2:18:27 PM(UTC)
dryer timer will not advance (Dryer Repair)
by Jlb86 2/24/2017 4:24:03 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Dryer Timer Will Not Turn (Dryer Repair)
Belarus danmanv2 10/17/2016 9:57:50 AM(UTC)
kitchen Aid dryer timer (Dryer Repair)
by stephane44 8/7/2016 1:36:28 PM(UTC)
