kgroat
#1 Posted : Friday, December 11, 2009 6:07:17 PM(UTC)
kgroat
When washer goes into spin cycle it gets locked up and won't turn. It looks like the motor is going in the oposite direction than it should be and it just smokes the belt. If you stop the motor and turn the drum by hand it turns in the oposite direction than the motor is running.When you tyurn it by hand it turns freely. Just replaced the main drum seal a month ago and it ran fine for a month. Then it started to make loud noise and now it is doing this. I never was around when it was making the noise to find the problem.
sidfink43
#2 Posted : Sunday, December 13, 2009 7:10:26 AM(UTC)
sidfink43
Can you confirm what is going on. The motor is supposed to turn counterclockwise in spin. Take off the belt and see if this is what is happening.
Here is the service manual for your machine which explains how the transmission works. On the surface it sounds like the transmission is the problem.
http://frigidaireservicetips.com/pdfs/488_3.pdf
kgroat
#3 Posted : Monday, December 14, 2009 4:19:54 PM(UTC)
kgroat
You were right it was the transmision!
sidfink43
#4 Posted : Monday, December 14, 2009 4:31:23 PM(UTC)
sidfink43
Well, sorry to hear that but at least you know.
Thanks for the update.
Dryer drum won't turn (Dryer Repair)
by JudyStud 6/16/2017 11:18:11 AM(UTC)
LG washer drum won't turn (Washer Repair)
by Jmccaslin 10/10/2014 1:58:48 PM(UTC)
heats up but drum won't turn (Dryer Repair)
by mark DeSimio 9/1/2014 7:39:27 PM(UTC)
by jonenright 7/11/2013 10:14:04 AM(UTC)
Electric dryer drum won't turn (Dryer Repair)
by angola20 1/11/2013 1:27:49 PM(UTC)
GE Gas Dryer - Drum Won't Turn / Locked Up (Dryer Repair)
by roma1625 10/31/2012 9:52:33 AM(UTC)
Need to open dryer cabinet, drum won't turn (Dryer Repair)
by scfp 10/1/2012 6:47:14 AM(UTC)
Drum won't turn (Dryer Repair)
by robprops 9/13/2012 10:53:55 AM(UTC)
Maytag Dryer Drum Won't Turn (Dryer Repair)
by ohiojt 6/10/2012 7:32:15 PM(UTC)
Washer drum won't turn (Dishwasher Repair)
by gregndella 12/8/2011 8:00:39 PM(UTC)
by paul.k.best@gmail.com 8/11/2011 6:59:00 AM(UTC)
by PohlmanM 5/23/2011 2:51:13 PM(UTC)
Cabrio Drum Won't Turn (Dryer Repair)
by cherawranger 5/9/2011 1:50:16 PM(UTC)
motor hum - drum won't turn (Dryer Repair)
by mrdth 2/5/2011 10:53:33 AM(UTC)
Kenmore 110 series drum won't turn (Dryer Repair)
by AtC 2/2/2011 10:18:05 AM(UTC)
