AtC
#1 Posted : Wednesday, February 2, 2011 10:18:05 AM(UTC)
AtC
My Kenmore Dryer won't turn the drum. When I select a program and then hit 'start' the machine acts normally and the expected time & temperature are displayed but there is no movement or sound coming from the dryer. Here is a breakdown of what I have done so far:
1. With the unit plugged in, I ran the diagnostics. The results were as expected in the service manual. The belt is fine, the connection through to the motor is fine, the idler-pulley appears to be fine and everything looks functional.
2. Tested continuity in the fuses. All of the fuses tested ok. One did not give a continuity result, it was the two prong piece on the blower assembly that is not the motor fuse (perhaps a cycling thermostat). The motor fuse tested fine. Could this be the problem? Can I short the connection to test if it will work?
AtC
#2 Posted : Wednesday, February 2, 2011 10:39:35 AM(UTC)
AtC
The part that is not giving a continuity reading is p/n 3976615 therm-o-disc.
Thanks!
#3 Posted : Thursday, February 3, 2011 1:21:47 AM(UTC)
Replacement parts for 110-64082202 models | AppliancePartsPros.com
When I look up on AppliancePartsPros the part number you listed it comes up as the thermistor AP3919451 (1/3 down first page). You should not short it. It should be about 10,000 ohms.
Here is the tech sheet, see the attachment.
Do the motor Test #2.
File Attachment(s):
64082202.pdf (220kb) downloaded 13 time(s).
