frogdoc
#1 Posted : Friday, February 22, 2008 4:14:50 AM(UTC)
frogdoc
The washer won't completely drain all the water in the spin cycle with heavier loads!It seems to function ok with small to medium loads.Is there a filter trap on this machine that can become clogged and impede water from getting to the water pump?
misterfixall
#2 Posted : Friday, February 22, 2008 7:38:47 PM(UTC)
misterfixall
is water taking longer than usual ?how long? to drain? check for kink in drain hose ,
Maytag washer mav6257aww user (Washer Repair)
by Bigredkansan 4/5/2024 6:17:18 PM(UTC)
Maytag washer mav6257aww (Washer Repair)
by Guest 4/5/2024 6:11:48 PM(UTC)
Clicking / creaky sound Maytag Washer (Washer Repair)
by Guest 4/1/2024 7:29:31 AM(UTC)
Maytag Washer Doesn't Complete Spin Cycle (Washer Repair)
by glmoore0001 2/5/2024 6:32:24 AM(UTC)
Maytag Washer MVWP575GW0 strange problem (Washer Repair)
by Macdawgg 11/18/2023 8:07:47 AM(UTC)
Maytag Washer Excess Suds during "clean washer" cycle (Washer Repair)
by DogHair 11/14/2023 2:04:58 PM(UTC)
Top load Maytag washer model Model LA410 with s/n 336623 (Washer Repair)
by Guest 10/26/2023 10:58:17 AM(UTC)
Maytag Washer MAH5500BWQ (Washer Repair)
by Guest 9/10/2023 4:01:49 PM(UTC)
MAYTAG WASHER MODEL MAH5500BWW (Washer Repair)
by Guest 8/21/2023 5:22:03 PM(UTC)
Maytag washer drive motor mount question (Washer Repair)
by Guest 7/29/2023 5:24:40 AM(UTC)
Maytag Washer Rise Cycle (Washer Repair)
by Ollie21 7/5/2023 6:03:49 PM(UTC)
Maytag washer control board burns out (Washer Repair)
by Guest 6/20/2023 2:12:48 PM(UTC)
Maytag Washer Not Draining F9E1 (Washer Repair)
by amappliancewi 6/16/2023 10:44:24 AM(UTC)
MAYTAG WASHER NO GOING INTO SPIN CYCLE (Washer Repair)
by Guest 2/27/2023 8:13:04 AM(UTC)
Maytag Washer shaking - badly (Washer Repair)
by chansman94 1/12/2023 6:47:51 AM(UTC)
