semerm12
#1 Posted : Thursday, October 22, 2009 2:50:40 PM(UTC)
semerm12
I have the above washer. It leaked about 2 months ago when we used it and did not leak again until a couple of weeks ago, and now it leaked a third time.
It leaks when it is agitating, not when it is filling or when it is spinning out. The leak is coming from the front left side of the machine? I looked there and from the top I cannot tell for sure but all the plumbing is in the back and in the right? Could it be the tub seal? How do I tell for sure?
I hate to get a repair man here as that will be $100.00 easy and it is a 10 year old washer... if we get this problem fixed everything else is still 10 years old and a new one is a little over $300.00. I also hate to go putting new parts inwithout knowing for sure- this can add up to over a $100 pretty easy too from what I see.
I looked at the parts diagram and it looks like there are only a few seals in there. I am not sure how to get the thing apart or if I should do so. I am slightly mechanically inclined but never took a washer apart before. I have a lot of general tools but none for this if there is anything specialized need.
#2 Posted : Friday, October 23, 2009 12:37:33 AM(UTC)
Maytag performa washer won't spin. It drains and i can hear the motor but tub appears stuck. (Washer Repair)
by Brittrepairs 12/21/2019 7:47:28 PM(UTC)
Maytag Performa washer fills, drains, spins, but doesn't agitate (Washer Repair)
by shshimo 3/9/2014 8:25:14 PM(UTC)
Maytag Performa Washer loug banging noise when stopping (Washer Repair)
by johncher 2/9/2013 2:43:39 PM(UTC)
Maytag Performa Washer Smoking (Washer Repair)
by Fixineer 1/31/2013 10:22:01 PM(UTC)
Maytag Performa Washer vibrates and walks (Washer Repair)
by Kurt_washer_2012 12/2/2012 5:54:40 PM(UTC)
maytag performa washer (Washer Repair)
by denise57 5/16/2012 9:11:20 AM(UTC)
Rat-a-tat noise from Maytag Performa washer (Washer Repair)
by Inspector Gadget 1/6/2012 3:12:50 PM(UTC)
I think the pump quite on my maytag performa washer (Washer Repair)
by ChevyCowboy 12/9/2011 5:24:18 PM(UTC)
Maytag Performa washer, slow spin speed (Washer Repair)
by hank b 4/18/2011 7:26:54 AM(UTC)
Maytag Performa Washer Will Not Agitate Sounds Like Bad Bearing (Washer Repair)
by plamberty75 1/13/2011 11:26:49 AM(UTC)
Maytag Performa Washer Leaking From Bottom While Filling (Washer Repair)
by mjones61 11/7/2010 11:00:15 AM(UTC)
Maytag Performa washer does not spin (Washer Repair)
by ret2002 8/10/2010 2:05:38 PM(UTC)
Maytag Performa washer timer knob removal? (Washer Repair)
by Albert P 1/20/2010 6:41:45 AM(UTC)
Maytag Performa Washer makes loud noise (Washer Repair)
by gsgray2806 12/31/2009 4:49:46 PM(UTC)
by scott_lngly 10/21/2009 6:40:23 AM(UTC)
