Rich Steiner
#1 Posted : Friday, September 11, 2009 3:18:19 AM(UTC)
Rich Steiner
I have a Dishwasher that when you push the "start" button on the front it will not start.
I have checked all the connections and have 120 volts.
I have installed a new "board" but still doesn't work.
The only thing I havn't check is the start button itself. Is there some way to check the button.
Rich
#2 Posted : Friday, September 11, 2009 6:02:36 AM(UTC)
Replacement parts for MAYTAG PDBL390AWB | AppliancePartsPros.com
Here is a service manual and a tech sheet
http://www.servicematters.com/m...ibrary/docs/16021814.pdf
http://www.servicematters.com/m...ibrary/docs/16026393.pdf
The tech sheet gives the procedure to check the keyboard using a meter.
Sometimes it is just a dirty track/connector.
If the ribbon cable is the type that just the insulation is removed (no connector) then it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive. Also connectors can be cleaned using electronics cleaner or isopropyl alcohol and a tooth brush. Just make sure all the solvent has evaporated before reconnecting.
Also hair line cracks can develop across the trails in the ribbon cable, a magnifying glass can help find these.
And of coarse last but not least, the bubble switch is toast which requires a keypad replacement.
Rich Steiner
#3 Posted : Friday, September 11, 2009 8:40:45 AM(UTC)
Rich Steiner
I check for these things and get back to you
Rich
butternut
#4 Posted : Saturday, September 12, 2009 9:38:20 AM(UTC)
butternut
wow, Maytag puts out a lot of useful info, unlike the sparing tidbits I found for my Frigidaire. The info from Maytag allows you to do some real troubleshoot of the control board and user interface controls.
Rich Steiner
#5 Posted : Saturday, September 12, 2009 1:44:35 PM(UTC)
Rich Steiner
Yes..
I ordered a control board from the factory today.
They say it's going to be till 9/30/09 until it gets to their wharehouse.
Oh well...
Rich
High-pitched noise with LG dishwasher (Dishwasher Repair)
by Guest Yesterday at 5:13:53 AM(UTC)
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Bosch Dishwasher dirty water in filter " hole" (Dishwasher Repair)
by Guest 5/14/2024 9:47:25 AM(UTC)
Bosch dishwasher SHVM78Z53N/01 (Dishwasher Repair)
by Guest 5/8/2024 8:58:29 PM(UTC)
Continuity TEst Samsung p/n 33299012 Dishwasher Water Inlet Valve. (Dishwasher Repair)
by cprodave 4/27/2024 6:55:56 PM(UTC)
Samsung DMT400RHS Dishwasher Over Level Water Error. (Dishwasher Repair)
by cprodave 4/27/2024 6:24:56 PM(UTC)
Samsung Dishwasher Water Inlet Valve--how to Test? (Dishwasher Repair)
by cprodave 4/27/2024 6:18:51 PM(UTC)
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
