Discuss
Maytag Gas Dryer
 in
Dryer Repair
I can't figure out how to take the front off of my MAYTAG PYG2300AWW Gas Dryer. I need to replace
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Maytag Gas Dryer
  #1 (permalink)
Old 02-22-2010, 05:08 AM
Junior Member
lxk8 is on a distinguished road
Default Maytag Gas Dryer
Model Number: PYG2300AWW   Brand: Maytag   Age: 5 - 10 years
I can't figure out how to take the front off of my MAYTAG PYG2300AWW Gas Dryer. I need to replace the igniter and belt and I don't see how to get access. I can get he top to swing up but it appears that there are screws (on the inside) that hold the front to the sides. There doesn't appear to be enough room to get a screwdriver in there to back them out. Help!
Ads By Google
Related Models
Maytag PYG2300AWW Dryer - Gas
Maytag PYG3200AWW Dryer - Gas
Maytag PYG3250AWW Dryer - Gas
Maytag PYG3300AWW Dryer - Gas
Maytag PYG3360AWW Dryer - Gas
Maytag PYG4500AWQ Dryer - Gas
Maytag PYG4500AWW Dryer - Gas
Maytag PYG4557AWW Dryer - Gas
Maytag PYG4558AWW Dryer - Gas
International PYGS244AWW Dryer - Gas
Maytag PYGT244AWW Dryer - Gas
Maytag PYGT344AWW Dryer - Gas
Maytag PYGT444AWQ Dryer - Gas
Maytag PYGT444AWW Dryer - Gas
Amana QDO-695 Range - S/c S/i Ddraft Gas
Amana QDO-695D Range - S/c S/i Ddraft Gas
Amana QDO-695E Range - S/c S/i Ddraft Gas
Amana QDO-695F Range - S/c S/i Ddraft Gas
Amana QDO-695G Range - S/c S/i Ddraft Gas
Amana QDO-695H Range - S/c S/i Ddraft Gas
Amana QDU-838 Range - S/c S/i Ddraft Gas
Amana QDU-838A Range - S/c S/i Ddraft Gas
Amana QDU-838B Range - S/c S/i Ddraft Gas
Amana QDU-838C Range - S/c S/i Ddraft Gas
Amana QDU-838D Range - S/c S/i Ddraft Gas
Amana QDU-838G Range - S/c S/i Ddraft Gas
Amana QDU-858 Range - S/c S/i Ddraft Gas
Amana QDU-858A Range - S/c S/i Ddraft Gas
Amana QDU-858B Range - S/c S/i Ddraft Gas
Amana QDU-858C Range - S/c S/i Ddraft Gas
Amana QDU-858D Range - S/c S/i Ddraft Gas
Amana QDU-858E Range - S/c S/i Ddraft Gas
Amana QDU-858G Range - S/c S/i Ddraft Gas
Amana QDU-878 Range - S/c S/i Ddraft Gas
Amana QDU-878A Range - S/c S/i Ddraft Gas
Amana QDU-878B Range - S/c S/i Ddraft Gas
Amana QDU-966 Range - S/c S/i Ddraft Gas
Amana QDU-976 Range - S/c S/i Ddraft Gas
Amana QDU-976A Range - S/c S/i Ddraft Gas
Amana QKO-661 Range - S/c S/i Ddraft Gas
Amana QKO-661B Range - S/c S/i Ddraft Gas
Amana QKO-661C Range - S/c S/i Ddraft Gas
Amana QKO-661D Range - S/c S/i Ddraft Gas
Amana QKO-661E Range - S/c S/i Ddraft Gas
Amana QKO-751 Range - S/c S/i Ddraft Gas
Amana QKO-751A Range - S/c S/i Ddraft Gas
Amana QKU-647 Range - S/c S/i Ddraft Gas
Amana QKU-647A Range - S/c S/i Ddraft Gas
Amana QMC811 Walloven - Std Mwave Ele
Amana QMD-800 Mwave - Family Size (60 Hz)
Amana QMD-800A Mwave - Family Size (60 Hz)
Amana QMD-800B Mwave - Family Size (60 Hz)
Amana QMD-800C Mwave - Family Size (60 Hz)
Amana QMD-800D Mwave - Family Size (60 Hz)
Amana QMD-800E Mwave - Family Size (60 Hz)
Amana QMD-800G Mwave - Family Size (60 Hz)
Amana QMD-810 Mwave - Family Size (60 Hz)
Amana QMD-810A Mwave - Family Size (60 Hz)
Amana QMD800 Walloven - Std Mwave Ele
Amana QMD800D Mwave - Family Size (60 Hz)
Amana QMD810 Walloven - Std Mwave Ele
Amana R-1 Range - S/c S/i Ddraft Gas
Amana R-1H Range - S/c S/i Ddraft Gas
Amana R-1J Mwave - Family Size (60 Hz)
Amana R-2 Range - S/c S/i Ddraft Gas
Amana R-3 Mwave - Family Size (60 Hz)
Amana R0-24-8 Mwave - Mounted Over Range/wo
Whirlpool R101
Whirlpool R1011
Whirlpool R1012
Whirlpool R1013
Whirlpool R1014
Whirlpool R121
Whirlpool R1211
Whirlpool R1212
Whirlpool R1213
Whirlpool R1231
Whirlpool R141A
Whirlpool R141A1
Whirlpool R141F0
Whirlpool R141G0
Amana R15 Misc / Accessory
Whirlpool R153
Amana R15A Misc / Accessory
Amana R15L Misc / Accessory
Amana R15LA Misc / Accessory
Whirlpool R183
Whirlpool R183A
Whirlpool R183A1
Whirlpool R183A2
Whirlpool R183A3
Whirlpool R183F0
Whirlpool R183G0
Whirlpool R183G1
Amana R1E Mwave - Family Size (60 Hz)
Jenn-Air R200 Surface Unit - Ddraft Ele
Frigidaire R2000DL0 Frg(v1) / Electric Range
Frigidaire R2000DW0 Frg(v2) / Electric Range
Frigidaire R2000LL1 Frg(v1) / Electric Range
Frigidaire R2000LW1 Frg(v2) / Electric Range
Jenn-Air R201 Surface Unit - Ddraft Ele
Jenn-Air R201-C Surface Unit - Ddraft Ele
Frigidaire R21CL0 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL1 Frg(v1) / Free Standing Electric Range
Frigidaire R21CL2 Frg(v2) / Electric Range
Frigidaire R21CL3 Frg(v4) / Electric Range
Frigidaire R21CL4 Frg(v6) / Electric Range
Frigidaire R21CL5 Frg(v2) / Electric Range
Frigidaire R21CL6 Frg(v4) / Electric Range
Frigidaire R21CW0 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW1 Frg(v2) / Free Standing Electric Range
Frigidaire R21CW2 Frg(v1) / Electric Range
Frigidaire R21CW3 Frg(v3) / Electric Range
  #2 (permalink)
Old 07-22-2010, 09:16 AM
Junior Member
headknocker is on a distinguished road
Default
Quote:
I'm having the same problem. I assume you figured it out at this point What did you discover?
  #3 (permalink)
Old 07-22-2010, 09:28 AM
Junior Member
Default
Quote:
Still trying to figure it out. The igniter started working on its' own. I'm waiting for the belt to fail to force the issue.
  #4 (permalink)
Old 07-22-2010, 12:06 PM
Junior Member
Default
Thanks for the quick reply. Did you ever get the front panel removed? If not, I figured it out around an hour ago. After prying up the top panel you simply remove the two upper screws holding the front panel to the side panels(one on each side) which allows the front panel to swing down. There's a hinge on the bottom of the front panel. The coils,igniter, etc. are right there when the panel is removed. Hope that helps.
Now I'm trying to figure out how to gain access to the rear of the unit as the sides and rear are one piece.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
maytag gas dryer will run then won't kennew Dryer Repair 3 10-16-2009 05:03 PM
Maytag Gas Dryer Steve Barbara Dryer Repair 0 08-27-2009 01:52 PM
Maytag gas dryer essy9 Dryer Repair 0 06-29-2009 01:05 PM
Maytag gas Dryer Dwasko Dryer Repair 0 06-08-2009 03:15 PM
maytag dryer not hot twojem Dryer Repair 1 11-07-2008 04:31 AM
