ss45402
#1 Posted : Monday, October 20, 2014 8:39:41 AM(UTC)
ss45402
this dryer is killing me need help. dryer heat comes on with setting control knob but the drum will not spin :confused: is this a door switch issue and can i bypass it just to see if this is the problem
fairbank56
#2 Posted : Monday, October 20, 2014 11:36:13 AM(UTC)
fairbank56
Groups: Expert
Heat should not come on unless motor is running so either the motor switch is bad or the heat element is grounded. Does the motor make any noise at all when you try to start the dryer? Unplug dryer, turn timer to normal heat cycle, check continuity between the two flat blades on the power cord plug. If you read through the heat element, about 10-12 ohms, then the motor switch is bad and motor must be replaced.
Eric
Amana electric dryer not working (Dryer Repair)
by Guest Yesterday at 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
WGD8410SW0 Dryer l (Dryer Repair)
by Hkfmike 4/27/2024 6:00:13 PM(UTC)
1998 Maytag Gas Dryer Drum Issue Has Me Stumped (Dryer Repair)
by semaas 4/22/2024 9:44:18 PM(UTC)
Whirlpool gas dryer model WGD8300SW2 (Dryer Repair)
by Guest 4/20/2024 7:14:50 AM(UTC)
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
DLEX5780WE lg dryer shutting off before the clothes are dry. (Dryer Repair)
by LMA 4/13/2024 11:00:21 AM(UTC)
help maytag comercial dryer (Dryer Repair)
Belarus blackwell316 4/4/2024 5:05:48 PM(UTC)
grease for rear dryer bearing (Dryer Repair)
by bronn033 3/30/2024 12:57:30 PM(UTC)
Kenmore Gas Dryer Running Hot (Dryer Repair)
by Guest 3/30/2024 6:24:53 AM(UTC)
Kenmore 100 dryer Heating Element (Dryer Repair)
by postalservice21 3/27/2024 6:43:17 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Samsung dryer motor (Dryer Repair)
by Guest 3/24/2024 11:17:52 AM(UTC)
Replacement dryer motor W11364931 (Dryer Repair)
by Guest 3/23/2024 8:47:41 AM(UTC)
