Discuss
Whirlpool gas dryer
 in
Dryer Repair
Dryer runs but the gas valve short cycles so little heat is developed. I have replaced the thermal cutoff on
Appliance Repair Forum > Appliance Repair Help > Dryer Repair » Whirlpool gas dryer
  #1 (permalink)
Old 02-03-2013, 03:23 PM
Junior Member
Chuckguy is on a distinguished road
Question Whirlpool gas dryer
Model Number: WGD5300SQ0   Brand: Whirlpool   Age: 1 - 5 years
Dryer runs but the gas valve short cycles so little heat is developed. I have replaced the thermal cutoff on the burner side , and the thermostat with internal bias on the vent side. Also changed the thermal fuse. Dryer performance has not changed, still cycling. Any help is appreciated. Chuckguy
Ads By Google
Related Models
Whirlpool WGD5300SQ0 29"gas Dryer
Whirlpool WGD5300ST0 29"gas Dryer
Whirlpool WGD5310SQ0 29"gas Dryer
Whirlpool WGD5320SQ0 29"gas Dryer
Whirlpool WGD5321SQ0 29"gas Dryer
Whirlpool WGD5500SQ0 29"gas Dryer
Whirlpool WGD5500ST0 29"gas Dryer
Whirlpool WGD5520SQ0 29" Gas Dryer
Whirlpool WGD5521SQ0 29"gas Dryer
Whirlpool WGD5530SQ0 29"gas Dryer
Whirlpool WGD5540SQ0 29"gas Dryer
Whirlpool WGD5540ST0 29"gas Dryer
Whirlpool WGD5550SQ0 29" Gas Dryer
Whirlpool WGD5550ST0 29" Gas Dryer
Whirlpool WGD5560SQ0 29" Gas Dryer
Whirlpool WGD5600SQ0 29" Gas Dryer
Whirlpool WGD5600ST0 29" Gas Dryer
Whirlpool WGD5700SW0 29" Gas Dryer
Whirlpool WGD5790SQ0 29" Gas Dryer
Whirlpool WGD5790ST0 29" Gas Dryer
Whirlpool WGD5800SG0 29"gas Dryer
Whirlpool WGD5800SW0 29"gas Dryer
Whirlpool WGD5810SW0 29"gas Dryer
Whirlpool WGD5820SW0 29"gas Dryer
Whirlpool WGD5821SW0 29"gas Dryer
Whirlpool WGD5830SW0 29"gas Dryer
Whirlpool WGD5840SG0 29"gas Dryer
Whirlpool WGD5840SW0 29"gas Dryer
Whirlpool WGD5850SG0 29"gas Dryer
Whirlpool WGD5850SW0 29"gas Dryer
Whirlpool WGD5856SG0 29"gas Dryer
Whirlpool WGD5860SW0 29"gas Dryer
Whirlpool WGD5900SB0 29" Gas Dryer
Whirlpool WGD5900SW0 29" Gas Dryer
Whirlpool WGD6200SW0 29"gas Dryer
Whirlpool WGD6200SW1 29" Gas Dryer
Whirlpool WGD6400SB0 29"gas Dryer
Whirlpool WGD6400SB1 29"gas Dryer
Whirlpool WGD6400SG0 29"gas Dryer
Whirlpool WGD6400SG1 29"gas Dryer
Whirlpool WGD6400SW0 29"gas Dryer
Whirlpool WGD6400SW1 29"gas Dryer
Whirlpool WGD8300SB0 27" Gas Dryer
Whirlpool WGD8300SB1 27" Gas Dryer
Whirlpool WGD8300SW0 27" Gas Dryer
Whirlpool WGD8300SW1 27" Gas Dryer
Whirlpool WGD8410SW0 27"gas Dryer
Whirlpool WGD8410SW1 27" Gas Dryer
Whirlpool WGD8500SR0 27"gas Dryer
Whirlpool WGD8500SR1 27" Gas Dryer
Whirlpool WGD9200SQ0 Gas Dryer
Whirlpool WGD9400SB0 Gas Dryer
Whirlpool WGD9400ST0 Gas Dryer
Whirlpool WGD9400SU0 Gas Dryer
Whirlpool WGD9400SW0 Gas Dryer
Whirlpool WGD9400SZ0 Gas Dryer
Whirlpool WGD9500TC0 Gas Dryer
Whirlpool WGD9500TU0 Gas Dryer
Whirlpool WGD9500TW0 Gas Dryer
Whirlpool WGD9600SU0 Gas Dryer
Whirlpool WGD9600TA0 27" Gas Dryer
Whirlpool WGD9600TB0 27" Gas Dryer
Whirlpool WGD9600TU0 27" Gas Dryer
Whirlpool WGD9600TW0 27" Gas Dryer
Whirlpool WGD9600TZ0 27" Gas Dryer
Whirlpool WGE30302 30" Electric Range Coil Cooktop
Whirlpool WGE32301 30"electric Range Coil Cooktop E - Z Clean Oven
Whirlpool WGE33001 30" Electric Range E - Z Clean Oven
Whirlpool WGE33301 30" Electric Range
Whirlpool WGE34303 30" Electric Range E - Z Clean Oven
Whirlpool WGE34304 30" Electric Range E - Z Clean Oven
White Westinghouse WGF317ESA White Westinghouse/range
White Westinghouse WGF317ESB White Westinghouse/range
White Westinghouse WGF317ESC White Westinghouse/range
Frigidaire WGF321WADA Wwh(v1) / Gas Range
Frigidaire WGF321WADB Wwh(v1) / Gas Range
Frigidaire WGF321WAWA Wwh(v2) / Gas Range
Frigidaire WGF321WAWB Wwh(v2) / Gas Range
Frigidaire WGF323BADA Wwh(v3) / Gas Range
Frigidaire WGF323BADB Wwh(v1) / Gas Range
Frigidaire WGF323BADC Wwh(v1) / Gas Range
Frigidaire WGF323BADD Wwh(v1) / Gas Range
Frigidaire WGF323BADE Wwh(v1) / Gas Range
Frigidaire WGF323BAWA Wwh(v4) / Gas Range
Frigidaire WGF323BAWB Wwh(v2) / Gas Range
Frigidaire WGF323BAWC Wwh(v2) / Gas Range
Frigidaire WGF323BAWD Wwh(v2) / Gas Range
Frigidaire WGF323BAWE Wwh(v2) / Gas Range
Frigidaire WGF324BBDB Wwh(v0) / Gas Range
Frigidaire WGF324BBDC Wwh(v1) / Gas Range
Frigidaire WGF324BBWB Wwh(v0) / Gas Range
Frigidaire WGF324BBWC Wwh(v2) / Gas Range
Frigidaire WGF325BADA Wwh(v5) / Gas Range
Frigidaire WGF325BADB Wwh(v1) / Gas Range
Frigidaire WGF325BADC Wwh(v1) / Gas Range
Frigidaire WGF325BADD Wwh(v1) / Gas Range
Frigidaire WGF325BAWA Wwh(v6) / Gas Range
Frigidaire WGF325BAWB Wwh(v2) / Gas Range
Frigidaire WGF325BAWC Wwh(v2) / Gas Range
Frigidaire WGF325BAWD Wwh(v2) / Gas Range
Frigidaire WGF337BBDA Wwh(v1) / Gas Range
Frigidaire WGF337BBDB Wwh(v1) / Gas Range
Frigidaire WGF337BBDC Wwh(v1) / Gas Range
Frigidaire WGF337BBWA Wwh(v2) / Gas Range
Frigidaire WGF337BBWB Wwh(v2) / Gas Range
Frigidaire WGF337BBWC Wwh(v2) / Gas Range
Frigidaire WGF337CBSA Wwh(v3) / Gas Range
Frigidaire WGF337CBSB Wwh(v3) / Gas Range
Frigidaire WGF337CBSC Wwh(v3) / Gas Range
White Westinghouse WGF350ESA White Westinghouse/range
White Westinghouse WGF350ESB White Westinghouse/range
White Westinghouse WGF350ESC White Westinghouse/range
White Westinghouse WGF350ESE White Westinghouse/range
Frigidaire WGF350SADA Wwh(v1) / Gas Range
Frigidaire WGF350SADB Wwh(v2) / Gas Range
Frigidaire WGF350SADD Wwh(v1) / Gas Range
Frigidaire WGF350SADE Wwh(v1) / Gas Range
Frigidaire WGF350SAWA Wwh(v3) / Gas Range
Frigidaire WGF350SAWB Wwh(v4) / Gas Range
Frigidaire WGF350SAWD Wwh(v2) / Gas Range
  #2 (permalink)
Old 02-04-2013, 01:55 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hello,
If the flame goes on every time when the igniter glows then there is definitely a restriction in the dryer vent causing the dryer to overheat and cycle on the hi limit thermostat. If the dryer vent goes on top of the roof then it must be cleaned by a pro. Also, dismantle the dryer and clean it inside.
If the flame lights up not every time when the igniter glows, replace the gas valve coils. Cleaning the vent and the dyer in such situation would not hurt anyway.
- The gas valve coil kit Part number: 279834
Part number: 279834
Here are the breakdown diagrams and Parts for Whirlpool WGD5300SQ0 Dryer - AppliancePartsPros.com
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Thin Twin Washer Dryer Combo, Dryer won't heat up NVChickey Dryer Repair 1 02-25-2012 11:52 PM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 4 06-18-2011 06:42 AM
Whirlpool Dryer won't start in dryer mode. hol99 Dryer Repair 7 12-27-2010 03:34 AM
Burned Dryer Plug - Whirlpool Electric Dryer EastCobbSnob Dryer Repair 4 11-17-2009 06:45 PM
Estate Dryer by Whirlpool/Dryer running but no heat tsm11238 Dryer Repair 1 11-06-2007 10:47 AM
