rinkugaya
#1 Posted : Saturday, September 24, 2016 3:17:35 PM(UTC)
rinkugaya
My Whirlpool gas dryer is having the below symptoms. Can you help me diagnose the problem:
- On heat setting "Medium (P Press)" setting. The igniter lights up good every 30-60 seconds but there is no flame.
- On heat setting "High Heavy" the igniter lights and the burner flame comes up first time for around 3-5 minutes. The dryer heats fine during this time. After this the burner goes off and does not restart. The igniter continues to light up good every 30-60 seconds.
Please guide on what part should replaced based on your best experiences to get this back to life.
ThatGuy
#2 Posted : Saturday, September 24, 2016 4:44:21 PM(UTC)
ThatGuy
Groups: Expert
United States
I'd say you need to replace your gas valve coils. They come as a set, so replace both. They get hairline cracks in their windings that work when they are cold and open when they get warm.
Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
rinkugaya
#3 Posted : Sunday, September 25, 2016 4:06:28 PM(UTC)
rinkugaya
Thanks. Will update the results after I replace the part
rinkugaya
#4 Posted: : Friday, September 30, 2016 2:49:10 PM(UTC)
rinkugaya
One of the screws on the coil is jammed and not coming out. I tried spraying little WD40 but it is still not coming out. Any suggestions?
ThatGuy
#5 Posted : Monday, October 3, 2016 1:57:54 AM(UTC)
ThatGuy
Groups: Expert
United States
If you've chewed the center out of the screw, you can still cut a slot in it with a dremel tool or a hacksaw. Then use a large straight blade screwdriver to break the screw loose.
If you haven't watched the repair video on the parts page yet, it can help you with reassembly. Good luck.
rinkugaya
#6 Posted : Tuesday, October 4, 2016 7:04:49 AM(UTC)
rinkugaya
Thanks. This worked and fixed the problem. Great forum!
